Another engine build
JMVELA
67
23
2012 335is
No, that was obvious :laughing:
Anyway it was a good reason for upgrading everything.
I would suggest not to continue using 14 degrees at 27 psi with forge pistons because you will be ending doing the same thing (damaging the engine on the long run).
Jern54
306
Netherlands
E91 N54 335i
Boost wil be lower as I will switch to TD04 turbo's.
But that combination would not make any harm to the forged internals.
I don't know on what you based this statement.
Btw
I am not speaking for track use intentions
Reactions: RuskiRacer
Btw
What pistons and rods are you going with ? Closed deck insert or will you run aftermarket sleeves and remain open deck?
SlowE93
1,832
Just a plane ticket away !
E93
Btw
Forged internals or not, 14° timing at 27psi is asking for knock on N54 on stock C.R.
IMO, it would still hurt forged internals, after all..... knock is still knock
Reactions: JMVELA
Jern54
306
Netherlands
E91 N54 335i
I've driven the car over a year on this set up. The car was tuned by Ken in combination with flex fuel. On E85 the tune was safe regarding rod knock. On pump fuel the timing advance reduced automatically.
Again, I've never had knock issues and the piston damage was not a result of rod knock.
  • Wow
Reactions: E92 420 and JMVELA
Jern54
306
Netherlands
E91 N54 335i
Got the engine back today from the machine shop.
Next week we will make a start with assembly.
Started today with determining displacement to calculate CR.
32cc on cyl 1 and 6, skimming has been done perfect.😎
N54Wagon
81
28
Texas
2008 535xi
Any updates on the progress? I’m looking at doing a very similar build to yours and I’m stuck in the process of selecting pistons rods bearings and whether I should sleeve the block or not
Jern54
306
Netherlands
E91 N54 335i
Sorry, time flies. In the mean time I have finished the break in of the engine.
This week I will install the PI manifold and connect the wiring.
Time to turn up the boost.
I went with ductile iron sleeves instead of the OEM cast iron sleeves to increase strength a bit and to maintain a piston diameter of 84.00mm. Closed deck was overkill for my target. I am shooting for 700hp at the crank. In this way I will have enough headroom for the HP800 turbo's.
Jern54
306
Netherlands
E91 N54 335i
Here some pics during the build
N54Wagon
81
28
Texas
2008 535xi
Very cool build if you don’t mind me asking why are you only going for 700 crank with the hp800s?
Jern54
306
Netherlands
E91 N54 335i
Reliable is the key essence now with the build.
Anyway, 700 hp will be quite difficult already to put down on the roads.
It is not a daily car anymore, but I still want to use it to take in on holidays etc.
  • Love
Reactions: N54Wagon
N54Wagon
81
28
Texas
2008 535xi
Makes perfect sense thanks. Can’t wait to see the power it puts down all spooled up!
Jern54
306
Netherlands
E91 N54 335i
@nyt you have some info and or clearances regarding the hi/low lift cams with some pistons?
I have the JE Ultra Series 9.5:1 pistons.
Valve pockets are more aggressive but I would like to know what is possible.
nyt
335
2010 335xi
Pretty sure the JE will fit whatever
