SYVECS running N54 _ WHo has one?
Keko
23
Brasil
Z4
Trying n54 DCT + syvecs + M3 conversion GWS with GTS software,lets see if now the clutch don’t slip
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
The M3 software has a lower max clutch pressure (15.5bar). M3 GTS only raises it to 15.8bar. The regular 335is / Z4is TCU software allows much higher at 17.5bar. If you are trying to make any real power I would stick with the regular TCU software.
1,923
662
Would the syvecs be able to control the dct though and then go to the hardware limit which if iirc is like 25 or 28 bar something crazy like that
Keko
23
Brasil
Z4
You can't use that TCU with our gearbox.
Well I did with my Z4 oem software and car started slip clutch after 580w,after M3 GWS and GTS software it’s holding till now 720w and we now going to try put more so I dun understand
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
Your DME tune was not optimal then and probably commanding less than the 15.5bar of the M3 software. M3 software expects less reported torque so you may be hitting the last breakpoint there in the TCU with your lower reported torque.
With a proper tune, the Z4/335is software will hold the most power.
Keko
23
Brasil
Z4
Really dunno how is this,we tryed everything on syvecs with oem software and my DME guy really know works with syvecs did a lot 1000w+ cars,can you help us how to make it ?
Keko
23
Brasil
Z4
Mayb
maybe because my Z4 is 35i and not one Z4is ?
LoBoost
251
172
2008 135i, 2014 GTR
Well, I'm up and running on Syvecs. So far it's made 623hp on 93 pump. Going to pick it up hopefully this Saturday and put a few hundred miles on it, and then switch to straight E85 and shoot for big numbers.
Ill report back on how the bluetooth module works out.
Keko
23
Brasil
Z4
M3 conversion too or oem ?
What about the m4 tcu, could that be transplanted into our cars and does it offer better clamping force.
