I think
@martymil and
@Torgus are talking about different points of "heat". I believe Torgus is referring to intake air charge, which will be dramatically lower at lower boost - compressing air heats it - that's why we use intercoolers - to get it closer to ambient.
I think Marty is referring to combustion heat and in cylinder heat - the same amount of horsepower regardless of boost should make the same amount of combustion heat.
If the only difference between the high lift and low lift cams are indeed lift, and duration is the same - then peak power RPM won't be dramatically changed running one or the other. Power under the curve
should be better with the high lifts tho, since added lift makes more power everywhere - remember you have more lift on valve opening and closing so much more air is flowing. I'm a proponent of high lift, ESPECIALLY when the cylinder head flows like a late 70s Chevy v-8. If it flowed like a Honda B or K series, then lift isn't quite as much of a concern because there is so much flow at low and mid lift.
The whole "too much torque" argument is worthless as stock turbos can build 30psi at low rpms and potentially bend rods (which I still do not think torque bends rods, detonation does, but that's another thread
) so just have your tuner "tune out the too much torque" and make more power everywhere else.
On my setup, since I probably won't ever run a helix or shotgun (too much $ for little return) I would rather improve flow overall and wold rather do a ported head than cams. Sure, a ported head AND cams would be great, but I think a ported head alone (or an N53 head, but damn the extra investment to do that) would be a superb mod for these engines. I'd expect 650whp with hybrids at under 25psi which would be AWESOME. And just imagine off boost responsiveness.
