They are figuring out the timeline needed but i would say roughly 2 weeks for delivery at most.
I'm saying when will the production run start/shipNo website, just a group buy on the manifold with the proper vendor @Sharp
All issues will roll through Sharp Customs and i will assist in areas that are more fitment/technical.
If there is an issue with the manifold Sharp Customs will take care of it. I had 3 corrections to the manifold in 30 days all arriving in about 5 biz days upon revision. So they are FAST to get them sent out.
This is a good insight, we had 3 of the Orings start to fail after only the 5 dyno runs, and after the last run the car went into limp because it blew one out, and had a large vacuum leak. We would not use the O-ring provided with the manifold at this point. As for fitment, it does fit, no issues there, but to get the rear intake on you have to run a 45 or 90 coupler, and run it up over the throttle body. To get the charge pipe on, I had to remove the throttle body every time. Just some stuff I noticed. I may run it in the future, I may not, undecided. All in all its a nice piece, but is a pain to get oni can't tell from those pictures but it appears to use aftermarket gaskets. I wont mention names but i use a port injection plate that uses aftermarket gaskets and I've melted 3 sets including viton's high temp seals.
if they made the front facing one where it had gaskets that use the oem seals and the throttle body fit properly id be all over this.
Yeah my bad, I was trying to edit my original comment but it just made a second one insteadMonday is the start with a 2 week manufacturing(approx) time as stated![]()
Keep an eye out for Monday to see the group buy. Pricing has been officially landed at 540.00 shipped. - same 499.99 price as before but with shipping charges now included.
Is this with Injectors and all PI stuff?
Been eye balling that link for a while, I might just pull the trigger on that , cut the middle manNo injectors.
No low pressure fuel line
no PI controller
https://cnbkc.en.alibaba.com/produc...ke_Manifold_with_fuel_rail_kit_set_black.html
Stock gaskets absolutely will NOT fit this manifold. We found orings we have in house that fit, and will hold up to the heat, its one of the orings we use in a turbocharger. The stock gaskets are better for sealing, but there is nothing magic about them. We used the ADE PI plate forever with round Viton orings, never had a single issue. Had many leaking issues with CPE PI plates, and they use the stock gaskets. Its all about crush depth, get it too little or too much, and you have issues. Little details matterSo just to confirm:
The stock gaskets will fit on this manifold?
I believe since you have a business license he would prob sell to you. Otherwise he wouldn'tBeen eye balling that link for a while, I might just pull the trigger on that , cut the middle man
Guys guess what time it is?!
CHINESE F***ing NEW YEAR.
So these are clearly made in China, which means we are now 2 weeks out as they all party on top of tables and pop bottles for 2 solid weeks.
Looking like a mid-late February for delivery for the group buy folks. 2 weeks for new years and 2 weeks production.
Well i am using the gaskets that came with the manifold and honestly im having no issue.
But i havent run my car super hard as im tracking down a misfire post shift.
Will be in for the gasket convo though too. If there are better ones that fit i will order some just in case.
