Oil Discussion
What is your preferred oil choice?
  • Rotella T6
    Votes: 41 25.3%
  • Motul 8100
    Votes: 23 14.2%
  • BMW Twin Oil
    Votes: 9 5.6%
  • Mobil 1
    Votes: 17 10.5%
  • Motul 300v
    Votes: 12 7.4%
  • Amsoil Euro Formula
    Votes: 5 3.1%
  • 8100 Excess
    Votes: 6 3.7%
  • Schaeffers Supreme 9000
    Votes: 5 3.1%
  • Driven DT40
    Votes: 0 0.0%
  • Brad Penn Grade 1
    Votes: 3 1.9%
  • LiquiMoly
    Votes: 23 14.2%
  • Castrol Edge
    Votes: 6 3.7%
  • Fuchs Titan Race Pro S
    Votes: 1 0.6%
  • Torco
    Votes: 1 0.6%
  • Motul X Max
    Votes: 0 0.0%
  • Castrol Edge A3/B4
    Votes: 5 3.1%
  • Red Line
    Votes: 5 3.1%
  • Total voters
    162
Bmwfixerguy1
875
292
07 335i MT
It's not magical but it's a Good group III and tests very well, I have been using it for years. Others haven't tested as well, such as RP, Castrol GC, etc.
If it was part of my maintenance plan and was free I'd roll with it but I just couldn't see myself purchasing it with a smile on my face lol..
Bmwfixerguy1
875
292
07 335i MT
Then it's a non issue.
I ran 5W-40 (only weight I think) T6 in another vehicle I owned and it tested pretty well, not quiote as good as M1 0W-40 but for the price it's great.
Tested as in? Like a VOA? A VOA of the two and t6 blows M1 outta the water!
Jsherry20
311
Has anyone used Brad penn in their BMW's? It's pretty widely used for race cars and people's daily drivers around me since it's made in Pennsylvania
Bmwfixerguy1
875
292
07 335i MT
I have not but I know it's great stuff! Something makes me wanna say that VTT stands by that stuff hardcore! I could be wrong but I feel like I read that before
I know @Tony@VargasTurboTech is a huge voice for correct oils for the job.. I belive he even linked the FP report on his site for awhile. May still even be up! Hope it is, very important little read/results!
Bmwfixerguy1
875
292
07 335i MT
Here is the link, I totally forgot what my auto one trip consists of every time I go till I read this!
So I usually grab a gallon of t6 and 3 qrts of vr1 non synthetic in the summer I grab 3 of 20w50 and winter 10w30
If I forgot that I think it means it's time to change my oil (I don't drive my 335 much lol)
  • Forced Performance Recommendations for Motor Oil.pdf
JAperformance
90
44
09 335i
I've used Mobil 1 0-40w for the past 4+ years without any issues. In fact with approximately 5k oil changes I haven't had to add any oil in between, but that's just my experience.
Reactions: Bnks334
Bmwfixerguy1
875
292
07 335i MT
I use to use Schaeffer oil in my Supra a while ago, great oil. But isn't the Supreme 9000 a Diesel engine oil?
A lot of the good oils are diesel oils. What makes a diesel oil desirable is the high zinc and phosphorus content. What's known as your zddp package. This is your anti wear and friction additives. Excellent for an ICE but in 2006 the EPA said horrible for cat converters! So they limited gasoline engine oils to I believe 900ppm.
That's not enough for what we do to engines and turbos!! Now diesels don't have cats so they can have as much as they want.. Off road race oils can have as much as they want as well because they don't have cats. So using a diesel oil is just an economical way of getting more zddp into your oil.. Diesel oil does have more detergent which some would argue is great and some would argue is bad.. I think a little more detergent isn't the end of the world :)
Hope that cleared that up a bit for you
DR-JEKL
35
14
I initially used castrol edge 5W30, then mobil 1 0W40, got some liqui moly 5W40 high tech to try next
Jsherry20
311
I'm really considering using Brad penn, it doesn't have any emission additives, it's made in my home town, and it's amazing + cheap. What else could anyone want?
Bnks334
530
344
Not a fan of anything listed. There is no real reason to run boutique oils its basically snake oil. People really like to make oil way more complicated than it is. 99.99% of the people on this forum don't do anything more with their car than some street racing. That's a far cry from race conditions where things like zddp additive can help buffer potential oil starvation issues (due to high g forces). Zddp additives aren't just bad for cats. Zinc also increases engine wear until the oil gets hot enough for the zinc to actually start working. Hence why it's still used in race oils where engine wear and cold starts is a non issue but catastrophic engine failure due to starvation is a real concern.
And for the drag strip guys, I know some old school hot rodders that would run straight 0 weight oil to get the most out of their engines.
N54 does have some real cooling issues stock, but unless your seeing 20+ straight minutes of oil temps over normal operating range of 250f then you have no reason to be using a thicker oil than specd. Yes, a higher quality oil (you dont necessarily need to run a thicker oil) will hold up better under that kind of high heat and shear but how many people here are endurance racing?
I run regular old tried and true castrol edge at hpde events and even after multiple track days and a few thousand road miles my oil is fine... That's with oil temps of 270f. I was at an event yesterday in 86f weather and oil pressure didnt drop off at all. A higher quality oil like redline might hold up longer across more hpde events, but edge is so damn cheap I can just change it after every event and get the same piece of mind if not more. I can change edge 4x for the cost of every 1x redline change... i knoe some the oils listed are cheaper than redline I was just using it as an example.
Reactions: R.G.
Bmwfixerguy1
875
292
07 335i MT
I couldn't agree more with you when it comes to economics of oil lol
I have to disagree when it comes to what's needed in oil..
Like I said a few times above I like T6, it has everything you want in an oil without the price tag :)
Reactions: TEC
rkundrat
535xiT 6MT
I switched from Mobil1 when I'd was declassified as an LL01 oil. (I realizethat doesn't mean it's no longer a good oil overnight...) now running the German Castrol Edge 0W-40. So far I like it better. Seems to be no consumption where as I was always down a bit with the M1...
Reactions: Vbp6us
Twisted Tuning
Oct 25, 2016
982
915
www.twistedtuning.com
N54 and N55 Cars
Yes it is. And that's what makes it great. Especially Moreso for a DI engine where fuel oil dilution is an issue. IN which the Schaeffers is designed (one of many things it's designed to do) To combat against.
And also what was said above by @Bmwfixerguy1 there are more reasons than that though of why I run it. But it would take a while for me to find all the testing again.
Reactions: JAperformance
