Oil Discussion
What is your preferred oil choice?
  • Rotella T6
    Votes: 41 25.3%
  • Motul 8100
    Votes: 23 14.2%
  • BMW Twin Oil
    Votes: 9 5.6%
  • Mobil 1
    Votes: 17 10.5%
  • Motul 300v
    Votes: 12 7.4%
  • Amsoil Euro Formula
    Votes: 5 3.1%
  • 8100 Excess
    Votes: 6 3.7%
  • Schaeffers Supreme 9000
    Votes: 5 3.1%
  • Driven DT40
    Votes: 0 0.0%
  • Brad Penn Grade 1
    Votes: 3 1.9%
  • LiquiMoly
    Votes: 23 14.2%
  • Castrol Edge
    Votes: 6 3.7%
  • Fuchs Titan Race Pro S
    Votes: 1 0.6%
  • Torco
    Votes: 1 0.6%
  • Motul X Max
    Votes: 0 0.0%
  • Castrol Edge A3/B4
    Votes: 5 3.1%
  • Red Line
    Votes: 5 3.1%
  • Total voters
    162
MacBB55
80
Northern California
2004 BMW 525I
I have a 04 525i with 122k on the engine currently, I have owned the car around 4-5 months now, prior to owning it I am unsure what oil was used in car, but when I did my first oil change in the car I used Valvoline full synthetic high mileage 05 w30, I like the way it feels in the car but if I'm right I believe I am getting worse gas mileage than when I got the car and one thing I know for sure is since doing the change I have developed a leak somewhere around the oil filter housing, most likely the housing itself which I am not sure is something that is caused by maybe not fighting the cap to the right torque, maybe the oil is thinner than what was privioiosly used causing it, or if the o-ring that cane with the new filter was bad and that's what is causing it. Another thing I have noticed since doing the change is that somewhere from the bottom of the engine, possibly the drain Pan I am leaking something as well, however this leak only happens when the car is running and it is a slight drip, it almost leaves behind the same thing condensation does when parking running the ac just a lil smaller of a puddle an I am almost positive its oil being left behind, I used a pump running thru the dipstick tube when I did my oil change so im thinking maybe I need to change the drain plug as well as seal there too? One final thing is somehow one qt of the oil I bought was conventional, the same brand and viscosity just not synthetic and it was added to the car awhile back when I noticed I was low on oil after a drive, since I haven't driven it much because I want to make sure 1 that this isn't going to mess the engine up at all and 2 if you guys think I should change the oil again soon an maybe go with 10w30 or 5w40 to see if that helps with any of the leakage im having?
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Here's my most recent used oil analysis for Motul 5w40 on E85. This was the oil I ran on the dyno when I put down 775 whp, and did maybe 40+ highway pulls on in addition to daily driving it. The most surprising part of this is the TBN / viscosity as everyone says change your oil after 2-3k for E85 depending on who you ask. Blackstone even recommended 5k despite being told it was on full E85.
Context for the comments: I told them this was a fresh oil change after the twins blew up, and that I found bits of what looked like turbo shaft seals in the old oil. This is the turbo failure and metal bits they're referencing.
Hyab00sta
24
2009 335XI
So are most of the T6 guys seeing slightly high temps? Live in Florida and deciding on switching from Mobile 1 to either 8100 or T6. 5-40w.
DCook
274
135
08 BMW e92
I avg 215-225. And around 245-250 wot back to back to back pulls. Single turbo, factory cooler. T6 5w40.
Car ate royal purple like me at a buffet.
Mobil 1 was less consumption, and t6 was about the same.
