OEM-Style Aluminum N54 Valve Cover
GnomeChild
California
e90 335i LCI M-Sport
What about the little screw holes near the coil pack openings? They almost look like they are tapped for screws already. Will B58 adapter plates work with this? Or alternatively can the B58 coils be mounted directly using those holes still?
I am extremely interested especially since this keeps the OEM cyclonic oil separators of the PVC system in place
AshwinLB
39
26
Toronto, Canada
2008 135i 6MT "Narrowbody 1M"
From what I’ve seen from Nosrok’s video, the holes seem to be tapped so the “fat bunny” b58 conversion should theoretically work. The “Nexsys-style” conversion kit should also work as well since the holes it uses are tapped.
Very few people have these right now so it will be tough to get concrete evidence that they would work for sure but I don’t see why they wouldn’t
AshwinLB
39
26
Toronto, Canada
A friend in our local BMW group reported he has installed the n55 , going great after 10,000kms and just recently installed an n54 version. The quality was great and no leaks. He used original bolts/hardware but, actually did use the supplied gasket, with no issues to date.
Do you know if he was able to use the original hardware without removing the sleeves they’re in? Or do they have to be removed?
2,267
813
My car needs a full engine bay refresh and I’m wondering if one of these is the way to go longer term ? I keep developing valve cover leaks and I’m just over frankly. 🤣
I am Jacks N54
88
Ventura, CA
e90 335i
Whatever you do, use an OEM gasket the first time. I just did the VC with a Elring which came with an Elring gasket. It leaked, swapped in OEM gasket and now no leak.
Reactions: aus335iguy
