NBT Car images
superwofy
142
214
Extracted from images-vehicle.db.
Filenames are hex offsets in the db.
Attached is the script I used to extract.
  • pngs-vehicle1.zip
  • pngs-vehicle2.zip
  • pngs-vehicle3.zip
  • pngs-vehicle4.zip
  • extract.txt
superwofy
142
214
I thought this would be funny as a PoC.
superwofy
142
214
The large one has to be scaled perfectly to fit the tyre overlays when resetting RPA/RDC. Not there yet.
Xantor
46
9
So you basically fetched the pictures, edited one and then were able to write it back permanently / override the existing one? So that means that theoretically you could NBT retrofit and edit in your E92?
Now that's dope. While I don't know how the extraction works exactly (yet) there might be a step-by-step guide in the future. I mean I can read your script partly but how would one even connect to the headunit?
superwofy
142
214
Yes, it's permanent/persistent etc.
You can put in anything yes, but it's not the easiest to make it look good, scale and so on. As it stands, it's not perfect I still need to work on it. For my own project I'm just going with the stock CIC images that I posted earlier. I'll release the full instructions when done.
Connection is via telnet exactly like in CIC. However, you need to open it up to enable. Already described here: https://www.spoolstreet.com/threads/ipl-serial-telnet-and-ssh.9172/
Reactions: Xantor and wheela
gtodev
For some of them it uses PNGs but not for many. See the photos. In this case how can I redesign those widgets? I found the widgets folders obviously, but I don't know how to edit the files if there is a way at all.
