For those that are interested in doing this we will be releasing a cast version of our upgraded intercooler for the S55 engines very soon. It will be a lot more cost effective then our current billet end tanks
With oem pieces coming in between 260-450 on eBay, it's going to have to be significantly less expensive than the current option to make sense, being that we still have to put together the rest of the charge and heat exchange systems. I'm certainly interested to see what you guys come up with though.For those that are interested in doing this we will be releasing a cast version of our upgraded intercooler for the S55 engines very soon. It will be a lot more cost effective then our current billet end tanks
Maybe an initial colab between you guys and @bantam could be a good opportunity then to show the N54 market what an A2W setup could do for us, and increase your customer base? Just a thought, or if you guys have an N54 in house that has availability for a project like this...There is no way to compete with a used intercooler from ebay, our core costs more than that haha!
Once you know the logic you want to use for implementation a Can shield could take all available data and process it into pwm or on off for the pump.
@bantam any chance you could get measurements of the ic at some point? I'd like to model up and run some analysis on an ic the same size as stock, but with the core designed around microtubes like the Mezzo tech A2W cores, and then see what the cost to produce would be. Basically just need the core length, width, and height are to start.
We have a few actually and it has been kicked around as a project on the back burner. Its very possible we can make this happen if there was enough interest. The system is definitely efficient, we have proved that on the S55. May even gain throttle response and a few more things as benefits. We have a lot of projects on the table at the moment, but we might look at this again!
something like this sounds ideal. Looking online, they appear to be quite cost-effective. Any links on where I could read up on these things?
stock m3 core length = 5 3/8", width = 11", height 3"
I guess it would not actually require any additional work for you guys to have the n54 as a platform. if we could agree on a test methodology, I would be interested to see the performance gain from using one of your coolers once my system is debugged.
How would / could this work out with a top mount single?
You'd reclock the compressor housing to with the outlet at the 1 oclock position instead of the 6 oclock position. Then a 100-120 degree silicone coupler would get the charge pipe running back to the W2A end tank. It would be even shorter piping than what you see here. And far easier/cheaper.
ETA: Or you could do a close radius pie cut charge pipe that would look killer made out of titanium and get rid of that ugly tight radius silicone coupler.
Most likely it will not without some creative mounting ideas. Lucky for you it fits our manifold just fine, even with the topside injectors!Thanks!
I wonder what the odds are of this fitting on top of the doc race intake manifold.
Most likely it will not without some creative mounting ideas. Lucky for you it fits our manifold just fine, even with the topside injectors!![]()
any thoughts on turning the turbo 180 on the manifold and really shortening up the feed to the top mount? you'd need a custom downpipe of course but that would probably be the shortest charge piping route possible
Yeah I don't have one to play with. Kind of just a mental pictureNot going to happen.
@bantam up and running yet?
