N54 Stock DME Flex Fuel
N54QC
127
67
07 E90 335i
That’s cause I bought all 300 of them that way you guys can stop complaining about @jyamona being the hold up.
Now I’m the gate keeper HAHAHAHAHAHAHA.
(Bow before me)
I just followed suit, just pre-ordered the next 300! Price just went up fella's!! Lol
Reactions: dyezak
Reaper0995
69
20
Correct. It allows you to run different fuel at different power (boost) levels with timing changing accordingly
I'm still confused.... your saying that's correct it won't change boost levels, then yes it allows different boost levels..?
I read the entire thread and still no clear answer, will this automatically adjust boost levels with different mixes of fuel? Simply put; would you be able to run a pump gas boost/power level, add e85, and without flashing run higher boost/power levels? From what little I can decider to this, it looks like the answer is no. It will adjust the fueling requirements to maintain the current tune, but no boost nor power level adjustments.
colo_evo
159
111
E90 335i MT
I believe it can change load request which changes boost.
Where can we get the XDF for this?
Nov 5, 2016
615
625
Bay Area
If it doesn't change boost, and timing levels based on E content its worthless, so my guess would be yes it does this.
dyezak
1,767
1,518
Plano TX
335is
I hate cross posting from other forums, I feel that's "poor form", but I kind of have to:
jyamona said:
You do get to specify what your tune is targeting, through the set of interpolation % maps, for fuel, timing, and load. Each has 8 cells, so you can, for example, set your targets for E10, E30, E40, E50, E60, E70, E85, E98 if you wish. Or any other interval, that's the beauty
ccbsecu
191
140
135i
Question- assuming this will work in concert with any stand alone PI injection controller as well...?
LamboLover
238
242
Everything
There are a few ways to get it to work with a standalone PI controller I can think of. If the PI controller is unaware of ethanol content, the DME controlled DI could compensate the total fuel delivery by an exaggerated fuel scalar blender.
dyezak
1,767
1,518
Plano TX
335is
Yes, this works with standalone PI. @jyamona has said there is an additional output from the ECA that goes to your PI controller to allow it to run a custom flex fuel mapping as well (that he will provide).
dyezak
1,767
1,518
Plano TX
335is
Bump for an update.
Realistically at this point @jyamona is in a lose/lose situation here. He can not give an update and people will be pissed. He can give an update that things still aren't ready yet but here's the status and people will be pissed.
There's no reason for him to take a beating until the update is, "It's ready for purchase guys and here's your link".
Sucks but true.
3,644
ccbsecu
191
140
135i
Bump for an update.
So....being back in the N54 scene only recently, I’m not as well versed in the hot points for this crowd. I’m a quick study, but still getting up to speed.
I am also starting a build and I am simply researching/acquiring products for the build.
dyezak
1,767
1,518
Plano TX
335is
Aww man, now days you have to disclose what record you are going for before you do it to be legit bra.
I’m going for the Black DCT single turbo with three floor mats a factory glovebox 245 front tire trunk liner removed 1/2 mike standing start while smoking a Cuban cigar record.
