N54 Knock Table Discovery Fund
nublike
335i N54 TTE550
Wow! Found this just now. Is there still a way to support this great project and donate?
I have some problems with false knock on my build engine. Thought about getting these for better analysing it: http://tunernerd.com/
You need some beta testers?
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
I'd contact @jyamona and ask him how it's going. It's only been 2 weeks or so since we met the donation goal though so maybe not ready for beta testing yet.
Reactions: Panzerfaust
Panzerfaust
637
439
Chicago
E92 335i
I've been traveling / away, so purposely haven't taken payment yet from Tyler. Probably start of next week.
That's very exciting to hear! I'm glad you're willing to do something like this on your own and to dedicate so much work to a bunch of people you really dont even know for the most part. I'm glad I got a chance to donate and support your work more than just from purchasing MHD.
Any chance this will also further help with the 6AT timing pulls after shift too? I know you can get and I do have pretty clean logs with the right tuning, but knowing that that's not an issue at all would be excellent.
nublike
335i N54 TTE550
totaly clear that it is to early for beta testing. Just wanted to make that offer...
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
Started on IJE0S first. The list grows :) Still about 24 more to go for IJ to be "table-complete."
27610
4,345
At this point I'm surprised he hasn't been tryping some of his words in hex on accident.
@jyamona do they also add any code protection in the form of obfuscation/packing or no? I'm currently working with someone on a PC application(reversing video game network protocol)and it has "Themida" which really makes getting anything done a huge PITA.
1,929
664
You think this could help post shift timing? I know you came out with bog fix for mt but you think we could do something for the auto and dct guys if this wont help? Also would it ever be possible to fi spark pull for torque reduction instead of timing ,I know their are some mentions of it but not sure If the logic is their.
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
They do bit packing on some things, but moreso for optimization and convenience, and to keep size down. They don't really obfuscate as they expect the security in place to keep people from being able to reflash in the first point. Also, working with assembly code is enough obfuscation to keep most people away haha.
So one thing I noticed is that is uses a different averaging constant for knock noise level during "transient" conditions, which is caused by a certain change (up or down) in maf or rpm. Does the timing post shift in autos log as a knock correction?
Panzerfaust
637
439
Chicago
E92 335i
How would one check if its specifically being logged as a knock correction? I was aware there were various reasons the DME pulled timing, but for some reason I thought while WOT the only reasoning was either "suspects possible knock conditions" or "detected knock" so to speak.
I have a whole host of logs of various scenarios (actual logging, hitting the gas a bit much while passing on the interstate, multi-gear acceleration tests from when I was stock turbo etc) if you have a way for us to check or if you need a big ol' ZIP of logs to see.
1,929
664
The time for recovery and the stages of reduction in timing pulled would lean towards the knock reduction algorithm controlling the timing pull. I always assumed spikes in cylinder temp due to pulled timing for the shift resulted in the timing pull but even with e85 and meth it still happens. This makes me belive either it's false knock detection or preventative but the randomness of which cylinder leads a strong possiblity of a much bigger load and more fuel altering sound on shift enough to register as slight predetonation in which case this may fix.
That is why I asked the other questions cause spark drop could stop those sounds and i thought you had worked on a solution in which case I was curious what route that was.
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
What do the knock correction channels log as after the shifts? Or does it only show in the normal timing params?
4,345
I think he's talking about
timing cyl 1 *crk
timing cyl 2 *crk
etc
vs timing correction cyl 1-6
@jyamona ?
There is Cyl 1-6 Timing correction and then the actual timing values of Timing Cyl 1-6 *CRK(which are all the same I guess).
