N54 Full Build with Specs and Parts list
The Convert
1,487
1,054
Ouch. Might want to brace yourself but the custom tools needed for the N5x series engines are pretty pricey. You're going to need the camshaft install tool (pricy $700-800) look at 3:30sec on this vid https://youtu.be/YktIgslaoIQ, front main seal tool (not bad, maybe a hundred bucks), there is also a bedding plate to torque the mains correctly and evenly (extremely pricy), and the main seal injection tool (I have no clue).
All told you'll end up spending well over $1000 (potentially close to $2k) just in one time use N54 tooling to put the engine back together correctly.
I paid like $350 for a tool that does the front and rear crankshaft seals. People have done the rear with wood screws and the old seal. The sealant is like $70 iirc and comes with the plunger and tips to inject it. Cam tool can be rented. No idea on the bed plate tool, but someone made their own bed plate tool as well and their engine went back together and ran. So, not too sure how "hard" it all really is. Biggest thing would be to follow BMW's instructions and order of operations with a close eye on the little details.
AD-ENG
122
140
Did you measure your bore first? 84mm pistons on a stock sleeve doesn't leave any room to make them round again if needed.
TEC
81
48
Hopefully he measured each bore and checked for roundness before he ordered the pistons.
JE's can be a loud piston until they warm up.
Modifyit
40
10
South Jersey
2009 335i
Can you keep us up to date on the prices so far and what you the budget is for the whole motor rebuild?
Hello, sorry for the late reply. Wow lol but its tough to remember all the prices but I'd say around 10k from beginning to end with the Turbo kit and etc
Modifyit
40
10
South Jersey
2009 335i
Hey, yes everything was measured prior to ordering the pistons and bearings. The cylinders were honed and re-measured also. I wanted to leave the bore and etc as close to stock as possible
Begood69
234
114
Fayetteville, NC
Just let say I got them to work on th bearings About a yr ago for Main king bearing ..
Begood69
234
114
Fayetteville, NC
Custom JE 10.2:1 Forged Pistons
Did i see 11.0-1 compression on those pistons??
Stock 10.2:1 ..
and yes u saw 11.0:1...
works great. Runs great.. except the damn 2a98 .. damn timing off again..
and no .. I have a new ledge and tephon so is not that. And yes I swap and clean solenoids and sensors..
I will check timing maybe tomorrow. But other then that!! 0 codes and already dis pulls at 23 psi.. NASTY power... can t believe it is a 6870g2... spool maybe better that the 6266 and smaller ones..
Pm me if u want more
4,348
Stock 10.2:1 ..
So what is the spool magic?
Begood69
234
114
Fayetteville, NC
;-( maybe not a 6266 then.. Wut about a 6262?
Ps: some of the ppl seeing my logs will speak.. and hope it will clarify a lil..
And knowing my tune is raw so far.. I know spool only should get better.. but that is another story.. gnite.
