My DCT conversion to M3 GWS/FLASH
RSL
503
Awesome, subscribing!
If I missed it, when you go to manual mode 6, does the stalk have any control over the launch control RPM? Might be too much to hope for, but really surprised it went this far with just GWS change, flash and coding. Please post the VO options that were added.
Curious what your tranny temps get to on the GTS flash and hard driving...
2,265
813
Hey @RSL
LC isn’t available with this as yet because we need power mode PID to come from the DME. @dyezak is going to spoof it with an arduino though... stay tuned
RSL
503
Nice. Even this much is enough for me to jump on it. So awesome the modes work.
Anyone who hasn't driven an M DCT doesn't know, but you'd never even think they were the same tranny. Even a decently tweaked 335is DCT is no comparison. OP isn't kidding when he says night and day difference.
dyezak
1,767
1,518
Plano TX
335is
I'll be trying to figure out how to set the following two flags on the PT_CAN bus next:
Address 0x399 byte 2, bits 4-7 Decimal Value 1 is off, 2 is M-Power
Address 0x399 byte 1, bits 0 and 1. 1 is off, 2 is M-Drive
Setting those two flags should enable this setup to enter Launch Control. I've got an arduino and a CAN shield...I'll try that first.
Reactions: aus335iguy
2,265
813
I’ve asked the peeps in the CIC hacking thread if they can help in any way. If they can put doom on the thing they can make it make popcorn .... in the meantime stick with it bud... nearly there!
houtan
653
331
135i N55 DCT; PS2
This is ridiculously awesome. Thanks for sharing your work. Fingers are crossed everything works normal with the stock dct diff.
dyezak
1,767
1,518
Plano TX
335is
I just enabled fully adjustable launch control on my M3 GTS flash. That's right, I was able to control my launch RPM with my cruise control stalk just like an M3 on the fly. Did it twice, then couldn't get it engaged again for a video :-/ So I've got work to do but the future is bright!
Oh yea...and M3 launch control is with DSC fully disabled, not just partially disabled like in the 335is. That means when I let go of the shift lever and launched at 3500rpm I had one hell of a ride.
LMB335is
301
189
FOB FL
13 335is
That's fantastic! Using your arduino?
Reactions: musc
RSL
503
3500rpm is lower than I'd expect, good deal. What is the engagement point, neutral until accel is pushed like the M or just letting off the brake like the 335is?
Keen to try it on the stock 2.56 and with no plans to change the diff. WOT shouldn't be too difficult to try to work around via tune, but any logs/vids of up/down/rev-match shifts before you do the diff swap would be great.
2,265
813
Could it be that the TCU doesnt need the actual can values for LC but just needs shifter position, traction control off and throttle down?
dyezak
1,767
1,518
Plano TX
335is
I don't think so. I think something fucky is going on. But the good news with something fucky is that we should be able to reproduce the situation/variables and force LC to come on at will.
dyezak
1,767
1,518
Plano TX
335is
So I got it to go again a few more times. I'm begenning to wonder if the M3 GTS ZB doesn't lend itself to a different launch control than the normal M3. Because the setup that gets it to work for me is:
M mode
Drivelogic 6
DSC Completely Off
Foot on Brake
Press shift lever forward until LC engaged
Floor the accelerator past the detent
release the brake then the shift lever
