IF YOU ARE HAVING VOLTAGE SPIKES IN YOUR ETHANOL CONTENT SENSOR Reading!
Here is the definitive fix.
Problem:
When a secondary fuel pump activates and deactivates
via relay, usually through a hobb's switch trigger, a voltage spike occurs in the ethanol content sensor reading. This causes forces the flex fuel box into an error reading and causes a host of related problems.
Other devices especially high amperage draw devices such as electric fans can cause the same issue.
Solution:
Check your relay. A normal relay with out suppression will not work.
My precision race works fuel pump harness came with an non suppressed relay causing this issue.
A relay with diode suppression, such as
bosch part # 0332019155 or equivalent 12v 40amp diode suppressed will work.
