Misfire only on ethanol after installing Reflex
sosiiick
17
My old setup was running fine. I had a separate 93 and e85 tunes with PI control using an AIC2.
I installed a Motiv Reflex to run a flex tune (so I wouldn't have to switch maps all the time) , control boost, control 2nd fuel pump. I also upgraded to b58 coils. When I am only using 93 (e15) the car seems to run great. We moved on to tuning on e and now the car is breaking up. I am currently at e50 in the tank, mix of 93 and x98. I had used flex fuel from Rofo (e65) and had the same issue.
Looks to me like its running lean and I'm not getting enough fuel but my tuner said the file is good and says its something with my engine. So far installed new plugs gapped to .018, new VTT b58 coils, stretched the springs out to make sure the coils have good contact and replaced seals and decouplers on the injectors.
What is the best way to see if my PI is working correctly?
Setup:
DocRace (6266 gen 1)
Motiv Reflex
750cc PI injectors
450 walbro x2
BMP upgraded fuel lines
VTT B58 coils
VTT billet valve cover
stock IM but have a VTT billet IM on order
Index 12 injectors
Radium universal OCC
Wagner IC
sosiiick
17
Reflex Manual Go to page 18 and use TunerPro to run a bench test.
Would I need to disconnect the fuel rail to see if the injectors actually spray when performing the bench test? I logged the reflex and it only tells me that the connect is good. It says 'Ok - No Fail' for all 6 injectors.
I emailed motiv last week. Still waiting for a reply.
sosiiick
17
Update:
I went back to n54 delphi coils and the car does not break up when boost kicks in now on ethanol. Car feels much better going into boost and logs look good. I found some issues with the wiring harness adaptors. New harness adaptors are being shipped out. I may just solder the b58 connector directly to my wire harness if the new adaptors still have issues.
4doorbmwpower
90
42
South Carolina
cp-e.com
2007 BMW 335i (the CPE car)
Update:
Do you have a log now that you got it fixed ? B58 or with the old N54 coils I am having a strange issue also. But I cant move it to another cyl so maybe wiring? not sure or leaning out on 1 cyl... its cyl 4 and only on E85
sosiiick
17
I'm still having the issue. The some of the pins on the adaptor harness were smaller just like the previous ones. It was causing a misfire at idle so I ended up just soldering the B58 connectors to my wire harness. I am still getting misfires at WOT only on e85. I replaced the VTT coils with OEM B58 coils but the metal springs in the boots are too big for the oem to have a good connection. I am waiting to hear back from Nexsus to get a set of their boots and springs and see if that fixes my issue.
Reactions: 4doorbmwpower
E30Lord
9
Did you ever figure out what the issue was? I’m having the same problem. Runs great on 93 but as soon as I start throwing ethanol into the mix it runs terrible on WOT. I suspect it has something to do with the ReFlex but I can’t pin point it. Going on 8 months with this problem and I’m at a complete loss
volfwaley
10
Did you ever solve this? Having the same issue, and feel like giving up. I have the latest firmware installed on the reflex, new plugs and coils and even refreshed the injectors. The misfire tends to move around but it always happens on e85, on 93 no problem. Maybe there’s something wrong with the harness?
E30Lord
9
No I have yet to find the solution. I reached out to Motiv to see what they had to say about it and after sending them a bunch of logs on 93 and E85 they told me they did not think it was a ReFlex problem. They said my Wastegate spring pressure and DC% don't really align on my logs which leads them to believe there may be some sort of leak whether it be a boost leak, manifold leak, or exhaust leak. Lower boost and pump fuel can be a little more tolerant of certain things compared to E85 since there is up to 40% more fuel volume.
I found a sizeable leak on my charge pipe where I deleted my BOV but ever since I fixed that I am dealing with the misfire on 93 as well. So I'm not sure what's going on. I have yet to do a proper leak test but I will be getting around to it soon. Hopefully that will shed some light on the situation. About to take the car to the junkyard at this point. It's driving me insane not being able to use the car to it's full potential lol.
volfwaley
10
The only thing I could get off mine was a MHD 005 error code which turned it to be a dirty ground cable, but the misfires still persist. Jake from motive said he’ll remote in next well to try and see what the real issue is, but you might be in to something about a boost leak 🤔
Yourbuddysatan
29
Not sure if this will help. I was having fueling problems with my motiv and come to find out the firmware was in dire need of updating. Used the boot loader and now my misfires are gone. Threw the car into a fit. I switched to single turbo and basically went thru everything. Updated the firmware that was just released last month and it’s good.
volfwaley
10
Sadly I have yet to get this fixed. Jake from Motiv is always busy and all I can do at this point is go through the harness and try to see if any of the pins are broken or connections are loose. All I have to go by is the ECA MHD005 error code and misfires on Cylinder 2 and 5.
Yourbuddysatan
29
Have you switched injectors around? Did you solder the jumper adaptor wires for the B58 coils?
Yourbuddysatan
29
Have you compression tested it? Are the Misfires constant? Sorry if you stated these things above I’m just looking to see what you have done compared to what I have done. I hd major misfire problems and check so many things.
E30Lord
9
Still dealing with this issue. I ended up taking my borescope inside the plug holes (after noticing a few plugs with heavy carbon build up) and saw the tops of the pistons were wet with fuel. So I ended up replacing my index 12s with a fresh set. Since installing the new injectors the car is back to running solid on 93 but it's still misfiring only on WOT when running ethanol. I thought for sure the new injectors would solve the issue but I'm back at the drawing board. I also sent my port injectors out to get ultrasonically cleaned. All six port injectors were flow tested and came back perfect. Even though my eldor coils aren't that old I swapped them with a spare set of eldor coils with no improvement. Also did a compression test just for fun and the numbers came back good. I'm just so confused. My STFTs are very negative and AFR is bouncing all over. LPFP and rail pressure is solid. Every time I go WOT on ethanol I only ever get a misfire code on random cylinders. It feels like I hit an invisible limiter as soon as the wastegate opens. I can't help but think it's something ReFlex or tuning related. Regardless I'm gonna keep digging but if anyone has some advice please chime in.
Yourbuddysatan
29
Can you post a log?
When it misfires what’s your boost at? When I was on twins the waste gates were so sloppy I couldn’t build enough boost vs the fuel and it would misfire like crazy. Put new waste gates in and ran like it should.
I bet I had like 1/16-1/8 gap when closed on the top of the disk inside the housing.
E30Lord
9
I have an ethanol log that I’ll link below but not an up to date 93 log for comparison. I was only able to get to about 5.5k rpms before getting a CEL. I don’t think I have an issue building boost. The misfires start around 21 psi. Also not sure why throttle would be fluctuating so much as I had good traction during that log.
https://datazap.me/u/slammede30/log-1711632161?log=0&data=3-24
Realized I have yet to mention my setup so here it is:
Speedtech bottom mount ST kit
Garrett gtx3582r
Turbosmart hypergate 45 wastegate
BMP port injection with 750cc injectors
Dual walbro 450s
Eldor coil packs
NGK plugs 2 step colder
Index 12s
Motiv ReFlex
