MHD Wifi
2,267
814
But I had a bimmergeeks adaptor. Had I known I could use it I wouldn’t have bought MHD wifi
Jern54
306
Netherlands
E91 N54 335i
Ok, I deleted the app and reinstalled it again. That seemed to do the trick. Also I’ve deleted 6Gb of stored monitoring data! Didn’t know that the monitoring function will use storage space on the phone (without making logs I mean).
spx
E82 1M Conversion + E92 M3
I just received my F series wifi adapter and the WiFi network is WPA protected.
Is there an out of the box password? I've tried all of the basic passwords with no luck. :cry:
F87Source
332
152
Canada
2017 Bmw M2
It's on the sticker that's stuck to the adapter.
F87Source
332
152
Canada
2017 Bmw M2
Ugh mine doesn't have a sticker attached, hoping the box is still in my trash and it peeled off.🤞
That's not good. If you don't have it message again and I'll get you my password on my adapter when I get home. I believe they're universal and it was something like: MHD_ENET
spx
Disregard - my brother opened the adapter for me he says the sticker was peeling off so he stuck it to the box which was in the recycling (was wondering why the adapter was sticky, that dumbass)... He just sent it over -- MHD_ENET for anyone else needing it.
Reactions: Terry@BMS
F87Source
332
152
Canada
2017 Bmw M2
Glad you got it solved! I knew it was MHD_Enet and the SSID was MHD_XXXX (X based on your adapter).
Vncung
07 335i
Just got my black adapter but can’t get it connect to my android. I keep getting the error “fail to obtain IP address”. I tried on Both my galaxy s8 and amazon fire 8.
I did some google and it says to change WiFi setting to static IP which I did. I was able to connect my android devices to the mhd adapter.
but My flasher app still doesn’t recognize it and keeps telling me “no cable or WiFi detected”
I tried uninstall and reinstall the flasher app still doesn’t work.
works
42
15
135i
Got my orange adapter. Plugged it in, joined the wifi and flashed the map of my E82 in 1m6s. Splendid product this.
mfractal
81
27
E90 Sedan LCI 335i FBO MHD E40
Does anyone have any experience with this? https://www.aliexpress.com/item/32834895531.html
It has an on/off switch so perhaps it won't drain the battery once you are done using it.
yes. I tried one of these and while the WiFi network appeared and I could connect to it mhd wouldn’t recognize the interface and wouldn’t work. Bimmergeeks cable would work just fine with it btw. As soon as I connected the adapter directly to the obd2 port mhd started working. So I don’t know if my exemplar is bad or what but in my case it didn’t work with the adapter even though bimmergeeks cable did work through it just fine as mentioned.
Stokes
279
184
Houston, TX
2011 BMW 135i
I've been running v2.x lately and while it looks nice, it's sluggish and there are gaps in the logs (ranges from 400-800 rpm gaps). Tried 4 devices and all the same; using the orange wifi device (E-series app). Anyone else experiencing drops in their logs? Also, anyway to install and use the older v1.8?
I don't use the OTS maps. When I installed a v1.8 APK I found, it doesn't tie back to google for licenses.
