MHD Wifi
typedRew
412
221
2009 335i xDrive
I deleted mhd and re downloaded. It seems to be better for now.
I’ll update tomorrow when I try to run it while driving more. For a quick flash it did work while it hasn’t even given me that option for a few day’s
Reactions: Jake@MHD
typedRew
412
221
2009 335i xDrive
I can confirm that this seems to have fixed it for me.
If you're having issues, delete the app, including the separate folder in internal storage, and re download and see if youre still having issues.
Logging for the 45 minutes to work, with 3 logs, and all was fine.
LukasRCS
135i
Has anyone found a solution to monitoring via a MHD wifi adapter while being connected to the Internet?
scrllock
267
153
2011 335xi
Bluetooth tether for internet from a second device... or just use the second device for your apps requiring internet.
houtan
653
333
135i N55 DCT; PS2
anyone having issues with logs not saving? starting using the adapter yesterday with MHD auto logging monitor. When i got home i realized not all of my logs were saved even though the logging had started and stopped. I am E series early N55 with orange adapter.
impuls
94
60
'07 335i
Check the extended WI-FI settings. There should be an option to automatically fallback to cellular internet. I am even flashing like that.
LukasRCS
135i
Sorry, I forgot to write that I use shared internet connectivity via bluetooth hotspot on my android device.
Nugs
60
49
Perth
So now this has been out for a while whats the consensus?
I'm thinking of switching from BM3 as I hate the wifi agent.
I don't currently own any Android devices, if I just get a cheap phone without any celluar access that should be fine right?
Also who would be the go to tuner to do a custom e85 map for a B58 with a Pure stage 2 and XDI pump?
F87Source
332
152
Canada
2017 Bmw M2
I like MHD, the wifi adapter is great and I love using the Ethernet port for esys and ISTA since it allows me to pick cable length vs. a premade enet cable.
BM3 has a Better interface imo, but apparently mhd is working on a new app I'm not sure. Mhd has way more features than bm3, but bm3 imo has way better ots maps. Imo mhd is probably the better of the two.
Twisted tuning is the best tuner for newer BMWs imo, he has a solid reputation in regards to making power and doing so safely. Plus he has a B58 Supra on hand so he's really familiar with the B58 which is great for you.
I wasn't aware the xdi was available for the B58, but if it is he can tune it as well.
Reactions: Nugs
Jewgo
65
28
1r
So I haven't driven my car in about two weeks. I go to drive it yesterday and MHD is having a hard time not crashing. It is on the latest update (1.9b). Every time I select the monitor it freezes after a minute or so and forces the app to close. I am using the orange WiFi adapter on a Samsung tab A.
Wifi adapter worked perfect on update 1.8 but on update 1.9b, where it even states there is a fix for monitor crashes, is causing my monitor to crash. Also, prior to 1.9b, I have never had an issue with this device and MHD before.
@jyamona
1,664
Datapoint, I just got the orange adapter for my E82, flash times are around 30-45 seconds down from 2+ minutes via cable. Haven't tested further but very happy so far. Even fits with the OBD port cover on.
Reactions: SSDD
Jake@MHD
Nov 7, 2016
1,614
2,080
Philly
@jyamona
Fix for this is being tested, should be pushed as a revision soon!
Jern54
306
Netherlands
E91 N54 335i
Today the monitor page gave also a lot of troubles. After two seconds all the gauges freezes and the app forces to close. Really annoying!
I will delete the app and reinstall it again.
Jern54
306
Netherlands
E91 N54 335i
XHP and not MHD
Reactions: SSDD and F87Source
