MHD teases N54 Antilag with the stock DME
Jake@MHD
Nov 7, 2016
1,614
2,079
Philly
The smaller size Fuel Spool and Fuel Start were from the old style FlexFuel XDFs (used w/ the FF format tool).
None of that is used anymore, and I was able to return the base tables of each of those to their original full size). The E85 copies are still the smaller size to remain backward compatible w/ old style FF tunes. The pump gas (base) tables are expanded to full size at flash time if someone is flashing an old style FF tune.
But if you want to use any of the new MHD+ stuff, you will need to update those tables. An old FF formatted bin should NOT be used as a base for starting an MHD+ tune as there is a lot of possibility for headaches there.
Zetra
22
Even if you disable underboost 30ff you still getting the Code in shadow and same for boost deactivation
mcleansc
110
99
E92 335i
I don't want to start a new thread for this question, but has the MHD licenses changed?
I flashed a custom map back in 2019, went to reflash it today so I could change a few things and it said I need the M Boost license? I'm guessing that's new since I managed to map the car without it in 2019?
And in keeping with this topic, do I need any additional licenses to get the anti-lag? My car hasn't been on the road since 2020 so I'm admittedly a bit behind.
TheFixer
547
387
Tennessee
2008 535i
Have you gone to the my licenses page? There's info there to help with licenses.
There were alot of updates between now an then as well.
Reactions: mcleansc
Jake@MHD
Nov 7, 2016
1,614
2,079
Philly
There was a long standing bug where you should have needed the m-boost lic but weren't prevented from flashing, that was fixed ~1yr ago now. No additional licenses needed for antilag.
mcleansc
110
99
E92 335i
So I've been gaming the system for years 😂 Thanks for the reply, can't wait to give the anti lag a try from a dig. Let's the decimation of parts begin 😁
alpherd
16
Does anybody have a link to the patch notes and/or instructions and where they can be found?
