MHD teases N54 Antilag with the stock DME
Jern54
310
Netherlands
E91 N54 335i
Strange, I have no issues on single bank fueling.
What O2 sensors did you used and placed where?
Just to rule out any mistakes
trb1
16
OE Bosch. Welded an o2 bung into the dp. Rear o2 is in the doc race location. Ordered a new rear o2 to see.
Reactions: boosted.n54
boosted.n54
18
2008 BMW 335xi
So I went ahead and replaced both my o2 sensors with new ones and I am still getting the same code. I am at the point where I am starting to maybe think it might be a bad DME or maybe some wiring is shot I have no clue at this point.
alpherd
16
Did you ever get this issue resolved? I replaced both my 02 and I am still getting the same codes as you.
alpherd
16
brandnewish
1972 Radio Flyer 90
You may have resolved this by now, but maybe this will help anyone else who comes across this issue when swapping to single bank o2.
If you were previously using ADV sensors, do not forget to reinsert pin #5 into the O2 harness. That pin should have previously been removed and tucked away to properly run the ADVs.
This was something I overlooked when initially swapping to single bank.
alpherd
16
I replaced both my sensors and no codes. Im blowing through 02s faster than I can replace them. I may give ADVs a try.
Kynetic335boost
Pittsburgh PA
07 335i E90 6 spd
You can see the patch notes in the app, open the side menu and hit "What's New". 3-port and single bank instructions are shown after you select the respective flash option
If you activate the single bank o2 and 3 port mac in the tune with the new xdfs we have do you still need to activate it on MHD? and is setting it to 1 activating it?
TOR COILS
35
n55
It will work properly and work with the DCT. RK Tunes S55 w/ DCT set the 1/4mi record using basically the same code / implementation as I have ported to N54
Hello, Jack. How does my z4 dct trigger anti lag when it is still? I have tried many times, but it doesn't seem to establish a boost. But when I move the vehicle and roll, anti lag can establish a boost normally. I'm a single turbo. I want to get a faster launch. Can anti lag work with the launch? DCT N54. Thank
yakima
You can NLS now. You just need to set your per gear rev limit to roughly where you want to NLS, then enable shift bog delete (and PI safety if you have PI). We do plan to make a "better" version where it would activate at your clutch in RPM, but no ETA.
hi jake. i can't get this to work. i tried it this way, all gears set to 6200. it does hit limiter at 6200 while in gear. but in practice trying to NLS it revs past that.
i've also tried seperately the rev limit (clutch pressed) table, but not really sure what the breakpoints represent.. that does seem to limit it at speed with clutch pressed. although it seems like soft limit? in practice it doesn't limit it when trying to NLS, it goes right past it again. any ideas?
and if you have any updates on the better version :)
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
If it is a soft limiter, then you do not have the shift bog fix and pi safety flash options enabled.
