it was selected, it didnt seem like it was working so i reinstalled mhd to make sure. but regardless, i lowered it way down so i could actually tell what was happening and i got NLS to work using the clutch pressed table. that must be the proper way to do it now? i firstly tried the per gear rev limit as you said but could not get that to work.If it is a soft limiter, then you do not have the shift bog fix and pi safety flash options enabled.
