Lets talk Aux fueling.. Shotgun or PI?
Jake@MHD
Nov 7, 2016
1,616
2,083
Philly
I would personally wait for @jyamona to finish his testing with switching the misfire response from an injector shutoff to an ignition coil shutoff.
I wanted to clarify this a bit as I'm not just changing it from one to the other. The end goal is that they both will be shut off, and not just for misfire events. Anything that causes an injector to shutoff will be applied to that cylinders coil as well.
bahn
Nov 5, 2016
250
414
Iowa
Thanks for the clarification, I knew that from our discussion in a different thread but forgot to mention that. I've edited my first post for clarification.
Shane303
44
Mesa, Arizona
2009 E92 335i
I have the same problem actually, I noticed some of my LTFT are off by quite a bit so I'm going to reset lamba adaptations and check again otherwise I've got to figure out whats wrong there first. Also, what does 14 mean for rail pressure on a jb4 log? 14x100?
The DME reads in megapascals. 14mpa=2030.528psi
LazyMe870
10
13
colinod
48
20
2007 e92 335
I think PI is brilliant with a map well tuned to your car. I was using a one size fits all map and was getting horrible overfueling across the board, even to the point of having it turn on when cruising at 40 mph at ~2k rpm and getting on the gas, leading to the car bucking horribly. now i borrowed a mates map who is also using an on3 turbo setup with 6AT and PI kicks in at appropriate times
The Banshee
175
104
Lehigh Valley PA
2008 335xi coupe 6466 MT
This would arguably be the best overall advancement on this platform in years.
The map supplied with the aic was meant for twin turbo, sounds like your mate retuned his for single and that's way it was running properly
The original map was basically a base map and a good starting point that's all
Don't know the whole story but that what it sounds like from what you told us
Pi can be great if tuned properly and everything is running right but god forbid something was to go wrong and an injector had to shut down
If @jyamona gets this implemented properly we have a cheap way of running high hp safely.
At this moment either its double barrel or syvecs with pi but it doesnt work with auto trans so not ideal for most
Mhd will be the solution eventually we all have to lay off and give them time to get it right
But small updates would be great to keep the impatient customers happy
Reactions: fmorelli
BlueN54
15
17
e90 335i
I personally would pick DI any day. The biggest reasons is that it is safer, and I don’t have to worry about another controller.
Also speaking on power- we all love the n54 and it’s a very very capable motor. 700whp is generally 28-30psi, which is A LOT of power/boost compared to the original power output. That being said, I believe you are possibly at risk for damaging your motor trying to run that much power.
There’s been all these recent blown motors with single turbos and quite frankly, it makes me worried. I just wanted to express my concerns because I would hate to see your beautiful Le Mans blow its engine.
TLDR: I guess what I am saying is although the n54 is capable, do not be surprised if something goes wrong. You are more than doubling its original output.
chadillac2000
233
255
NC
2008 BMW 135i
While I agree that I also hear all the time of PI induced blown N54 engines, it seems a bit overblown, yeah? Do we have any first hand accounts of PI ruining an engine of anyone that regularly posts on the forums? While I'm sure they exist, I can't remember running across any threads where there was, and there are hundreds of people running PI on high HP N54 applications without issues. Most blown engines I remember reading about seem to have come apart after running a lot of boost while pulling timing, or having inadequate fuel.
I prefer one fuel system, so I'll overdrive with a shotgun when the turbo(s) go in, or maybe move to the M4 fueling system if @BQTuning figures it out. This is why my current round of upgrades were to get the fuel system and ignition system rocking, minus installing my shotgun which we'll do when turbo(s) and HPFP go in.
But that said, PI has been used in lots of places for a long long time. I suspect the bigger issue with failures probably has to do with inadequate factors - poor work, hack tuners (the N54 having enough safeguards that lots of people can play), shortcuts, worn out cars, etc. I suspect - built right and cared for right - for whatever configuration one chooses, one can run a pretty reliable car.
I personally know of one motor that let go under pi when the cylinder shut down
And had it happen to me but caught the di shutdown in time. I could feel it.
Its really only people that keep the power on that do blow the motors but you can only do this a number of times and eventually the motor will let go
Personally i backed off the power level in my car as its totally unnecessary and undrivable to run with kind of hp safely and switched over to double barrel
Reactions: chadillac2000
