I have a few micron dust collection system in my guitar building shop. It has a 36"x30" or so pleated cannister filters. Periodically I have to clean it out. I can see the dust because a lot of my wood colors are dark exotic hardwoods. Let me tell you, with a hose I spend 30 minutes getting to where the water comes out clean. I'm unconvinced that the K&P filter gets cleaned they way they do it.
If I had this filter, I'd consider buying a gallon of acetone, putting it in a sealed container (like a paint can), and dunking the the filter in there, where I could vigorously shake it. A better solution would be something that screws to the filter and lets you push fluid from inside out (like a large syringe/plunger).
The issue with the spray approach the video shows, you will get no spray force on the filter to dislodge metal particles, and you can't reach the top 20-30% of the filter from the inside. With my dust system I can get right on the inside of the pleats with a high-pressure water hose. That's what it takes ...
I like the magnet, though.
I fully agree with filippos statment that cleaning on that way does not do the job.
My profession is with hydraulics and there these kind of metallic mesh (not as fine as this) has
always been outperformed with paper or glassfiber reinforced paper units so my vote is going for stock, 50-90% of metallic partickels on these kind of engine is not magnetic before engine
seize, nornal bearing lead copper or aluminium so the magnet is doing only part of the job,
nice feature othervice and better than none.
