Just had my trans fluid + filter/pan done and was told specifically NOT to reset adaptations. The prescribed ZF learning procedure is pretty difficult to do unless you've got a lot of open road or a dyno handy, too.
xHP recommends the same: https://www.facebook.com/xhpflashto...-controlsince-the-launch-of/1923761651273188/
My understanding is that it should only be done when hardware is being changed out, not just for fluid changes. I'm sure there are people doing it regularly, but surprised to see contradicting info from PD. Curious what their reasoning is.
While it's true that the adaptions only need to be reset after major changes to the system, like hardware and such, our reasoning is that the ATF was initially a "life-time" fluid per BMW/ZF. We all now know that is not the reality. As most on here know, mechanical fluids undergo drastic property changes due to friction over a given time interval, especially at high power levels, so the TCU compensates accordingly with adaptions. We recommended the reset based on an assumption that the fluid being disposed of during the rebuild had already run its life cycle and the new fluid needed to start from zero so to say. This is one of those things that will fall under user discretion depending on circumstances.
