GS7 program code disassembly project
690
You mean ZB 8606092 HW 8606066 SW 8606093DA ?
Can you ask any F8x DKG files?
"Does not have full Dump " - we need any fulldump for E9x, is it possible?
Yeah. I am on it. Asked already for "any" full dump.
Can you give me ZB, HW and SW from the F8x ones? It is easier if i can directly deliver data.
Is Full Dump equal to ORI File?
Look what just showed up at my doorstep from @aus335iguy
Olza
239
244
BY
BMW 320d
I need to know what is stock wheel size for M3? Want to calculate speed from OSS speed.
For example for 3.23 final drive ratio and REAR 245/40 R17 wheels it is: X/3.23*3.14159*((245*0.40*2)+(17*25.4))/1000000*60.
I need that formulae for M3 and stock 335, please.
690
I just had a call with Alientech in germany and a very nice person!
He agreed that he will make no business with us but just wants to help!
So he will check with an engineer he knows to check available Dumps of that TCU. Data has been shared.
If no software is available he said that if we will find a car in the area of the company with their hardware we may get a car there and they would read out the software for us.
690
M3: 265/35 ZR19
335: 255/30 ZR19
The M3 or M3 GTS?
2,271
817
Are any members here from Germany ?
690
Don´t worry. I want this as much as you want ;)
I am sure that the ZSUB will not be relevant in the first place. If we will get a dump of my or any other version i will donor my car.
Also the guy told me if we will need the DAMOS then we will find a way.
But now the most important thing is that they hold the word and we get a dump.
Reactions: DirtKurt
Wow, any information we can get on this process the better. Really want to see the bootloader get exposed somehow.
Olza
239
244
BY
BMW 320d
calculations in TCU for M3 GTS:
_speed_ / 16 = (_oss_rpm_ * ( _X_318 * 600 000) / (_final_drive_ 3.15 * 100 * 100)) / 10000
so in 7 gear (1:0 ratio) output shaft speed rpm is 4000: (4000 * 190 800 000‬ / 31 500‬ ) / 10000 = 2 422,85714 / 16 = 151 kmh
X value 318 im assume is wheel factor.
question: what is his dimension? inch, mm, cm, just factor? 31.8?
amg6975
278
188
2012 135, 2005 ZHP, 2009 fJCW
Good question. The GTS has 285/30-19's right? Circumference is 2053.3mm (80.84",) diameter is 653.6mm (25.73".)
