Finally new dyno results with our VTT 135i!
pysical
471
108
2009 335xi E90
Ah ok. Thanks for both replies. Just trying to gauge where mine will be until it is tuned.
Terry@BMS
Jan 23, 2017
464
380
I was over doing expensive builds and just wanted something inexpensive and functional. The high lift cams+springs added around $2k to the build, not sure if it was worth it. Seems to have added 500rpm+ of usable range. But not sure if it's adding any peak power.
1,624
Being able to stay in gear longer with a 6MT might be worth it.
pysical
471
108
2009 335xi E90
ok thanks. glad the majority comes from the head. i can live without the 500 extra RPM even though im MT.
pysical
471
108
2009 335xi E90
@Terry@BMS
What plugs are you running? Since our setup is so similar and I am in the market for some I was wondering what you had. I run the 95770 (one step colder) right now. But was thinking about going to the 97506. Do you recommend?
Thanks.
JMVELA
67
23
2012 335is
Terry, on a car that only can rev up to 6700 rpm, do you think it is a good upgrade changing cams to the lower lift ones? What are your advises in this regard? Thanks
Terry@BMS
Jan 23, 2017
464
380
The cams I think in most cases, not worth it. Especially not if shifting earlier.
MoreBoost
361
143
Been a long time coming, but our white 135i is finally back together!
Sometime in 2017 the stock motor gave up so we shipped the car up to Vargas for an entirely new build. Budget oriented forged motor, GC2 turbos, and various little bits and pieces that made sense while it was all apart. While I was happy with the MOTIV 750 kit we've already got the ACF single turbo 335 in our stables here. I was intrigued by the potential to make the same or more power at half the price, in a cleaner looking twin turbo package, so made the switch to GC2s.
Basic Build Details:
JB4 with MHD BEF
VTT GC V2 turbos
VTT/Rebello Short block CP 9.5:1 pistons, Manley Turbo Tuff Rods, King bearings, ARP Rod bolts
Stock head, stock valves, stock retainers, Supertech Valve springs, new guides, new seals ARP Head Studs
Schrick High Lift Cams
VTT Upcoming crank hub fix, with Crank bolt capture
VTT Stock location rear inlet, relocated front inlet
VTT Crankcase Breather
Fuel-It PI w/ stock intake manifold
Fuel-It Stage 3 LPFP with Return
Spec 3+ clutch / Aluminum SMFW
ADE Engine mounts
UUC Red Trans mounts
Custom 3.5" aluminum catback
100% Pump E85
Tony got everything up and running last week and was kind enough to help me do a little preliminary remote tuning on their dyno just to see where things stand. Overall, I have to say I'm pretty impressed with the GC2 turbos. They are so responsive on the dyno I had to dial down spool dramatically. And they seem to hold power pretty well up to 7500rpm. I plan on shifting it around 7000rpm but it's nice to know the turbos can keep up with the cams if needed.
Below are a few of the last runs we did poking around at different timing curve and boost requests. I'm confident once I get the car strapped down here and can really spend some time with it we'll see power in the 775whp range. But even if nothing changes on that front, I expect to get this in to the 5.6s range or better 60-130. View attachment 16066
Also want to thank Tony personally for all the work that went in to it. I changed my mind a few times on some of the parts used which caused annoying delays and the car to have to be stored there for months. Which I can tell you as a business owner is usually annoying. He didn't complain when he had to go chaise down the many parts you lose when swapping from single back to twin. And also had a lot of little ideas to improve things that I never would have thought of. I'll leave it to him to reveal some of his built motor secrets should he choose. View attachment 16067
Anyway can't wait to get the car back down here so I can start having some real fun with it again. View attachment 16068
What was the spark plug setup on this car Terry?
