Engine building tips
4,348
Until I get my tune dialed it hard to say. But it's single scroll and spools about the same as top mount twin scrolls or pretty close. I'd say that a twin scroll bottom mount would be the best option for spool. It's just a matter of getting it to fit with a good manifold design.
Kenjermen
78
75
N las vegas NV
That's not bad, the 6870 is terrible on lag
4,348
Lots of people have a massive turbo I would never want to drive around town. Glad I got the 6266. Not sure I'd be happy with something bigger to be honest.
Reactions: Kenjermen
4,348
If I was waiting for a great deal to pop up to build a shortblock, would you guys recommend looking for just a bare block and crank or a complete short block?
Kenjermen
78
75
N las vegas NV
some teaser pics of the update
Kenjermen
78
75
N las vegas NV
O I forgot to mention on here, there was a split production in 2009 with the crank and fly wheel. The old style where a 8 bolt style and they switched to a 6 bolt style which is currently used on the n55 as well
Nov 5, 2016
615
625
Bay Area
For those looking for the torque on the ARP head studs
http://www.raceeng.com/c-6617-n54b30-hardwarefasteners.aspx
I would be very very very very careful with this info. If those are the "N54" ARP studs most shops are selling, the 11mm Studs are too short, and do not go all the way down into the block. With this issue, trying to put 82 ft/lbs on them. The odds are decent you are going to pull the the threads out of the block, which will ruin your day.
Just an FYI, we have never once had a head gasket issue, and we do 75 ft/lbs on the PROPER LENGTH 11mm Arp studs, and 50 on the 9mm studs.
I will say it again if using the shorter chrysler studs they sell as N54, put 82ft/lbs on them at your own risk.
JuniorB
343
112
Rhode Island
07 e60
You would think Arp would build the correct length! These motors will be seeing 4 digits,and they want to run short head studs?? Motor looks great! Nice work!
Reactions: Sshec152
