DOC Race N54 Intake Manifold Released
1,663
very interesting. Is the test data available? Also want info on that charge pipe, and what else is required to make this fit. Want to know if manifold comes tapped for all hookups, or if nonPI version is a blank.
N54Trnsfmr
15
2009 BMW e92 335i
How much does it weigh, and what are the packaged dimensions? For international shipping.
lamia2super
103
27
Miami, FL
2007 BMW 335i & 2016 Tacoma
could you also option it with 750cc injectors? any pictures of anything with PI?
DOC_Race
18
38
This was the prototype.
DOC_Race
18
38
is the manifold modular for port injection? Like if someone buys the one without PI will it come with places for injectors to go just plugged up so that later on if they decide to run port injection they can just source the injectors/PI stuff?
Good question. I will check with OCD works and see if he can build a "dummy" fuel rail. Since the holes will have to be drilled though the price likely will not change much going w/o PI. Might as well just go for PI.
1,067
Are you saying leave the injectors in, just unused/not connected to anything until such time to enable port injection? Or would it be best to leave the injectors out and plug the ports with appropriate bolt/plug hardware?
Reactions: Clean WHP
To plug the ports you need a fuel rail and injector plugs. So you still have to do everything except you're buying plugs instead of injectors.
Reactions: suspenceful
Clean WHP
173
136
2010 135i Msport 6MT
thanks for the clarification guys. so it would make much more sense to just buy the PI version
ninjacoupe
91
73
What about moving the throttle body? What is involved with that?
For my front facing FabFactory I needed to cut and extend the throttle body harness, the TMap wiring and the vacuum hose that connects to the throttle body as well. It would be nice if Doc Race had jumpers made up but is by no means a difficult job if you can crimp/solder and shrink wrap.
1,663
I feel like this needs to be a complete kit with required extensions for the variety of harnesses involved. Minimal additional cost to the vendor for a much cleaner product. Maybe include that if also purchasing the charge pipe???
2,198
Yeah they should really offer plug and play extensions. Small money. Big difference imo. Looks alot cleaner as well.
dyezak
1,767
1,518
Plano TX
There's a business opportunity for anyone who wants to chase down TYCO part numbers and build 50 throttle body extension harnesses. Charge $50/ea... Someone makes a bit of money...
@Omar@VaderSolutions BlackMarket @Payam@BMS @Terry@BMS ETC ETC
