He means the EOS spacer. I run it on my car, works good and has studs.Eoc?
@DOC_Race can you please respond? This is holding up at least 1 sale for you, probably many more.
As an example of the various colors of just red or powdercoating: https://www.google.com/search?q=pow...uabaAhUF3IMKHYytD8IQ_AUICygC&biw=1920&bih=987
https://www.google.com/search?rlz=1....0...1c.1.64.psy-ab..0.1.113....0._HodVagmZAA
I'm surprised anyone would order the IM without the fuel rail and injectors. Even if you don't plan on using them it really is going to cut down your resale value/market without them. Also, you never know when an E85 station will open around the block in the future. Just plug the ports. Not sure if there would be any issues with leaving the injectors installed and just not using them so everything seals nice. Someone who knows more about fuel injectors please feel free to chime in on having them installed for say a year or two but never using them, then starting to use them 2 years later.
Except you'd be silly to keep a sandwich plate over dedicated PI provisions.its for the people with port injection already lol
no need to buy PI twice, IMO
If the manifold fits with a spacer is the question. These are not the largest engine bays. Also, if the spacer moves everything an inch or two how does that affect the ic to throttle body connection/pipes? You may need to engineer your own solution with an offset silicone pipe etc. Is it worth the hassle?
As the spacer is just more points of failure and more potential boost leaks I can see no reason to run one with a manifold that has provisions for it. It is just asking for issues and adds complication every time you need to remove the intake manifold.
I'm a big fan of doing it right and doing it once.
Sell your spacer.
Again, I don't see why anyone would order the doc race intake manifold without full provisions. It's small money at the end of the day and a correctly priced spacer should sell quick.
Sell your spacer.
Someone who is only looking for the visual upgrade or someone on a budget. Its an easy way to save a few hundred bucks if you don't have much in the way of power goals and just want to get rid of the fugly waffle intake.
Adding the 1 inch port injection plate in addition to the manifold will make the charge pipe useless. It will also make less room available for the coolant reservoir and power steering reservoir which is already tight on space. Judging from my FabFactory I wouldn’t recommend it.
Never used a sandwich plate myself, but I believed in them as bridge options before we had PI support like we do now. I was a fan of TBI as well, for the limited purposes that it served anyway.
Have had PI for a year and a half. not one issue.. ppl gotta stop buying MMP lol. My Motiv plate is completely fine.
"every time you need to remove the IM" lol how many times do u need to do this?
then u say im a big fan of doing right and doing it once? LOL but PI has been out for 2 years for this car.
