very interesting. Is the test data available? Also want info on that charge pipe, and what else is required to make this fit. Want to know if manifold comes tapped for all hookups, or if nonPI version is a blank.
You gonna but one since you sold your fab factory?good work docrace!
Will be early morning.sooo when on friday will the link go live? haha im sure we all want to know
This was the prototype.could you also option it with 750cc injectors? any pictures of anything with PI?
is the manifold modular for port injection? Like if someone buys the one without PI will it come with places for injectors to go just plugged up so that later on if they decide to run port injection they can just source the injectors/PI stuff?
You're buying me one John? You're such a good friend.Interested on 2x ea 3” chargepipe
Please add to group buying.
Good question. I will check with OCD works and see if he can build a "dummy" fuel rail. Since the holes will have to be drilled though the price likely will not change much going w/o PI. Might as well just go for PI.
To plug the ports you need a fuel rail and injector plugs. So you still have to do everything except you're buying plugs instead of injectors.Are you saying leave the injectors in, just unused/not connected to anything until such time to enable port injection? Or would it be best to leave the injectors out and plug the ports with appropriate bolt/plug hardware?
What about moving the throttle body? What is involved with that?
… and injector plugs.
so fuel rail is on top or bottom of manifold ?
I feel like this needs to be a complete kit with required extensions for the variety of harnesses involved. Minimal additional cost to the vendor for a much cleaner product. Maybe include that if also purchasing the charge pipe???
For my front facing FabFactory I needed to cut and extend the throttle body harness, the TMap wiring and the vacuum hose that connects to the throttle body as well. It would be nice if Doc Race had jumpers made up but is by no means a difficult job if you can crimp/solder and shrink wrap.
