I will be using a ceramic coating on my exhaust components to keep heat in. If I were to do something to anything in the intake stream or coolant system, it would be a heat rejection coating.I am assuming you are coating cerekote on your exhaust to keep in heat from bleeding onto the underside of the car... if you use the same coating on your radiator or intercooler...that would keep the heat inside those units and increase IAT temperature...? Or are you saying he is coating exhaust with cerekote and intercooler, radiator with a coating opposite of cerekote properties...namely heat radiating coating for intercool and radiator.
