Clark Performance Fab 135i
Mar 14, 2017
418
346
Minot, ND
2010 135i
Just got the subframe in and checked clearances. This thing looks perfect!!
chadillac2000
233
255
NC
2008 BMW 135i
Impressive progress in a short amount of time. Must have felt very good to see everything clear the subframe with room to spare. Seems to have much better fitment than a lot of the kits shops charge money for. Looking forward to seeing more. Any updates on the oil drain?
Mar 14, 2017
418
346
Minot, ND
2010 135i
Thanks man. The manifold has been in and out of the car probably around 20 times now to check clearances. Hopefully this is the final time I’m gonna have to pull it before its running. I’m going to run the drain and feed towards the front of the car away from the manifold and wrap the ends closet to the hot parts with fire sleeve.
I don't know what's more impressive, the fab work, or how you found time away from your significant other to complete this!
Dude you don’t know how pissed off my wife has been. I probably would have been done a while ago if I didn’t do my best to spend some time with her. She has been great about it.
AZN54
32
19
Mesa, AZ
Great progress!
Why a banjo and not a 90° fitting on the compressor housing? I just received my kit with same turbo; realized the straight NPT to -4AN adapter I purchased isnt going to work with the filter on. Planned to order a 90° until I saw your setup.
Mar 14, 2017
418
346
Minot, ND
2010 135i
Great progress!
A 90* 1/8 NPT to 4AN adapter wont have the clearance to thread into the hole. The angled bit will hit the compressor when trying to. Thats why I used the banjo. Very simple and effective.
Reactions: chadillac2000
AZN54
32
19
Mesa, AZ
Makes perfect sense; glad I asked. Thank you.
I wonder if there would be enough room to use a 90* swivel, like this https://www.summitracing.com/parts/vpe-11351/overview/
Should allow room to thread in the NPT without having to worry about AN adapter contacting housing. Just not sure about the full height of the fitting VS bottom of filter.
