You don't need to bypass the drivers in the DME with a 3 pin inductive coil afaik (use PR as an example) you just disable multispark to allow for more dwell time. You can also supply the coils with a dedicated 12v source to unload the DME a bit, but most drivers can handle 30A some standalone's upwards of 40A.
The issue with the R8 coils is that the signal has to be 5v square "high" signal to trigger the driver in the coil itself. The DME provides this signal to the drivers inside of it, but the drivers do not output the same square 5v. They send a "Low" signal switched ground telling the coil to charge/discharge, hence the harness/chip-set to alter the signal from the drivers and the harness also provides the coils with a dedicated 12v that isn't drawn from the DME. Over on bummer-boost there was a bit of dissection on the signals and the BL harness itself.
no trolling, just want to be able say I have GTR parts bro
