ATM exhaust teaser
Tony4143
17
E65, E92, 88 MCSS
One of these days I’ll go catless. But it’s my DD and the missus has a super sensitive sense of smell, especially to anything under the hood or coming out of the tailpipe that’s not air or water vapor. :)
My wife is the same way and I have AA downpipes on my car and you can't smell anything out the exhaust.
ATMSpeedShop
27
335D
KevinC39
234
118
Looks real similar to the Black Market Racing exhaust in the first post. Looks good though.
ATMSpeedShop
27
335D
Thanks! Yea most 3.5" race exhausts will look similar for the most part. Their routing is different though. And we're aiming to be at a considerably less price point :sunglasses:
KevinC39
234
118
That's great to hear about the price. The price and the volume of theirs were my two big gripes. It's really loud. I put 30 miles on it and took it right back off.
BOosted 335i
315
104
New Jersey
E90 BMW 335i
When will the 4" tips be available?can I get some pics of them and the total size length.i am assuming there 3" to 4" tips correct?
ATMSpeedShop
27
335D
Awesome, update but whats the eta?? price etc??
-Tony
We will have 15 or so sets in about 2 weeks! Then just have to get the hardware kits and instructions together, etc. And we are still good for sub-$1k as planned :grinning:
4" tips will be the standard with these. However, the tips you see above were an afterthought, these are a shorter rolled tip we were testing that we plan to use in the future. The tips on our first batch will be a plainer 4" angle tip but they can always be swapped out easily by the end-user. This is exactly why we went with slip-joints on the tailpipe connections, you won't be locked down to the tip we supply in the kit.
npowered
08 E90 XI
ATM 3.5" race exhaust for RWD installed on XI w/no mods:
I just had my local shop install this exhaust on my 08 e90 xi. I had been communicating with Dave and he was willing to let me test their new 3.5" race exhaust they have been working on for a while on my XI. Turns out, and despite the massive 3.5" piping, the system fit perfectly. The only thing that wasn't used was a minor bracket as the transfer case was present.
From the shop that installed it for me (Harrison Motorsports in Roswell, GA):
This is Sergio Ramirez from Harrison Motorsports, I wanted to provide and update for the 3.5 race exhaust we installed in Darren's 335xi. The install was pretty straight forward no custom fabrications was needed, it took a lot of adjustment and the clearances were a bit tight in some areas, but it was a straight forward bolt on job. The only bracket we were unable to use is the one that attaches to trans in center section due to transfer case, but we tested exhaust multiple times in different conditions and temperatures and found the exhaust held strong no signs of needing the extra mounting location. Below you will find a link to all the pictures we took and a video, if you have any more questions feel free to contact us thank you. https://www.smugmug.com/gallery/n-LrQzbG/i-9khpGxN/A
The key to this install was the adjustability left to right and up and down with slip-joint connections. Again, this is huge. You can get the exhaust to fit perfectly with the right adjustment in several areas.
The system looks and sounds amazing. IMO, the noise is not bad. I went from stock to this so it's a big bump in sound volume, but there's no droning. Only a change in resonation between 2.5k and 2.9k. On WOT, this thing sounds freakin' amazing from 5k - 6k. Startup is quite loud due to cold start, but idle is fine and I can make it quite a bit quieter during partial throttle.
Obviously, my opinion is just that and my observations are subjective. Full transparency, I did receive a discount on the exhaust (thanks Dave!), but only to make up for what a shop would charge for an install and any mods if necessary. TLDR; this isn't a freebie, fan boy review.
I have MMP3s on 25lb and e50 so next step is to get back on the dyno and see if it opened them up a bit. And tweak my tune.
Thanks for reading and I hope we can get more XI owners with as great an exhaust as I have around the country!
