6AT to DCT Converstion
Begood69
234
114
Fayetteville, NC
Gear ratios, no... But you lose out on hardened axles, better diff (debatable), GWS, bigger gear display, etc... The pros are not doing months of hardware changes and customization on the parameters. :p
I have all I need to custom the full tune. No issues with gts anymore. 2 already running the custom tune. And myself. Luv it
azshantris
155
141
2011 135i N55 DCT GTX1000
Modifying the m3gts file. And flashing same way as when flashing gts after swap.
I need in on this. Was loving the M3 GTS swap but having some slip issues and funky shifts on kickdowns and whatnot. Enlighten us please!
Begood69
234
114
Fayetteville, NC
Just PM me. U r not the 1st with this issue. And they luv my adjustments. I just need some info on ur setup. I adjust to it. And make it wprk way better for our n54 tunes. (Need tune rpm limit, diff ratio, and power goal) i make d shift maps more sporty and default LC to ur prefer number and way more.. i install thru teamviewer with the standard tools.
azshantris
155
141
Definitely will do, though I'm N55 i believe the trans behaves the same way. I think I just found you on the Facebook group too.
Reactions: Begood69
Begood69
234
114
Fayetteville, NC
Have you had any issues with flashing GTS tunes @Begood69 ?
No man. And now that i customized the tune even less. Made sportier on D mode. And ratio adjusted even to the 3.08 i have. Increased line pressure. Everything is smoother. Also force shift maps adjusted to my rpms limit as per dme tune 7990. All just much much better.
But even as a untouched tune i had no issue with slippage before. Only happened when i 1st tried before i had relearned the clutches.
Begood69
234
114
Fayetteville, NC
GROUP BUY: M3/M4/335is DEKA DCT stage 3 clutches and steels 10x ppl:
- @John H (ST3) (installed)
- @Tommy B (ST3)(Shipped) 18Mar21
- @james N (ST3)(Shipped) (paid) 18Mar21
- @Jon S (ST3)(Shipped) 18Mar21
- @Freddy T (ST3)(Shipped) 18Mar21
- @omar (ST3)(Shipped) 18Mar21
- @Josh V (ST3)(Shipped) 3April21
- @Aymen L (ST3) (confirmed)
- @Michael A (ST3) (confirmed)
- @Daniel R (ST3) (Confirmed)
- @Soyon K (ST3) (crashed but deposit) TBD - -
--- @Michael M (HD1300+) (Shipped)
$2000 shipped from NC to your place in USA. Paypal begood6969@hotmail.com as friend or cover fees.
Fredm21
22
Bmw 335i e92
Hi Guys, might be planning on doing the swap if I can source all the parts needed here in Canada. Just wanted to know if the first post was updated. Can I use these infos to get everything done.
My dme was swapped in the past, so I was wondering if I really needed the Abs pump, and all the others components as written under the DME section?
Also Will I need the dct driveshaft and Axles.
Thanks
Reactions: Begood69
AzNdevil
604
290
Hong Kong
Replace DSC Sensor Plug. The DSC sensor should be connect to DSC unit follows
DSC UNIT > DSC Sensor
39 > 4
27 > 2
11 > 3
28 > 1
After this you should calibrate your DSC unit and sensors. ( use bmw ISTA to do this ),
small update from imad777 from the other forum copied over here for pre 08 cars
A little of correction. The F-Can goes to 11 and 26, not 11 and 28. And the pin numbers of the sensor are 3,5,2,1 of the sensor (instead of 4,2,3,1). Final mapping would look this way:
39 -> 3
27 -> 5
11 -> 2
26 -> 1
39 (CLUS SP, wires to sensor pin #3)
27 (CLUS GND, wires to sensor pin #5)
11 (F Can High, wires to sensor pin #2)
26 (F Can High, wires to sensor pin #1)
m_a_itani
23
BMW 335i M3 converted
Hey guys,
last weekend I did the wiring for my dct swap. Iam a little bit confused because my old X6021, X6031, X6041 female connectors that came from the transmission has 2 rows with 4 big Pins. So my original male connector has it, too. The new connectors of the dct wire have 1 row 4 big Pins and one row with 8 small Pins like the wiring diagram.
Can anybody tell me if that is normal?View attachment 22829
Hello there, did you manage to get the DCT swap working?
Fredm21
22
Bmw 335i e92
39 -> 3
27 -> 5
11 -> 2
26 -> 1
Are you sure? My 2007/06 is wired this way already? Im done with the shifter wiring... I think. Now I jumped to the dsc sensor but like I said, my oem pin out is the way you mentionned already...?
E90TommyB
37
Indiana
2007 E90 335i
Hello, I have succesfully dct swapped my 2007 335i but my paddle shifters don't work. I swapped the wires from the blue auto trans connector to the black dct connector in the dome box but my paddles still don't work. Any idea's?
Begood69
234
114
Fayetteville, NC
Want to confirm.. dsc vin car vin and trans vin do they have to match. Im tracking his dsc vin differ from "szl", from tranny and kombi. He also have issues doing the relearning of the tranny. He needs some help. Also i am not sure of the dsc part number but will b good to know it. He swapped no changed vin just calibration and it worked without error codes. I am wondering if it is a dsc_90.
Dipp
15
Brooklyn ny
Hey guys ,Would I be able to use a e9x m3 dct transmission harness for the dct swap since I’ll be going the m3 gts route ? Any confirmation on this would be greatly appreciated .
