6AT to DCT Converstion
enfiftyfour
16
hey, kinda late to the party but im dealing with 3 issues that i cant get past.
1. im throwing a shadow (inactive) 2AD0:
No message from transmission control unit,
receiver DME, transmitter EGS / HIM / SMG / DCT. i assume its a coding issue. causes transmission malfunction but transmission is not under any failsafe meaning i can go through all the gears at any rpm i please.
2. when in D sport, my transmission shifts a lot (night and day) faster than when its in S/M sport. any idea why? could this be due to the transmission malfunction im getting?
3. i recieved a INA0S file from my customer tuner but i was unable to flash it onto my DME. any solution?
thanks in advanced. been doing as much research as i could but couldnt find solutions.
That4chanhackerguy
71
11
Can you provide the description of 2AD0? I dont memorize faults but I do definitions.
enfiftyfour
16
hey thanks for reply. all it says is
"No message from transmission control unit,
receiver DME, transmitter EGS / HIM / SMG / DCT"
no insight fault or fault strategies. thats all i really get to work with.
That4chanhackerguy
71
11
in INPA go to E90>ENGINE>MSD80>Status>Digital>variants>clear>all. then clear codes cycle igntion. This is how you reset variants. The DME will continue to look for items it once captured and will throw codes if that item is now missing.
armenh7
20
13
I think there's a mistake for the transmission ZUSB.
7600042 doesn't exist. The closest I could find was 7640042 which then goes to 7642099 which then goes to 8606092.
Additionally, it appears if you flash to the latest version, CF26 fault gets stored which can be ignored according to BMW.
That4chanhackerguy
71
11
Here are some follwing ZUSB numbers per application the converitble and coupes do have a different one but it doesnt really matter its one higher or lower
8606068 335i (mostly EU)
8606070 135i
8606072 135is
8606076 335is
8606076 Z4 35i
8606082 Z4 35is
enfiftyfour
16
thanks for reply. i just saw that thread as well. if thats the case, how can i go about this? im tired of this transmission malfunction appearing everytime i start the car. i am on the latest software update meaning the car wont go anywhere unless my seatbelt is buckled.
Thanks!
armenh7
20
13
Thanks!
What are all the fault codes?
enfiftyfour
16
CF26:
Message (ZV and lid status) from CAS incorrect, receiver OCT/EGS, transmitter CAS/ACC/DSC
and another code about paddle shifter voltage incorrect (i never got to rewire my paddles so this does not shock me)
and thats it for the transmission.
armenh7
20
13
CF26:
Does buckling the seatbelt get rid of the malfunction?
DSteele41
@doublespaces
I'm in preparation to do this swap from 6AT to DCT Transmission
My Car: 2008 E93 N54 Production Date of 02/06/2008
I have 2 Questions From NCAT initial writeup
1.) DSC Pump (34 51 6 789 308 or 34 51 6 863 356 ) - if you have 2008/09 just skip this part
I have most of everything I need from the swap from a guy
The DSC I have in hand has this part number: 34 51 6 789 303; which differs by 1 digit from 34 51 6 789 308 from the writeup
Per my local BMW Dealer this is what we concluded
"part number 34516789303 is not showing in the supersession. Sadly BMW does not always keep printed part numbers in supersession"
My Question is if the DSC I have ending in 303 came from the same car of the DCT Transmission is it safe to say it will work with the swap ?
The other option is there's one on E bay that has the 2nd part number from the write up for sale : 34 51 6 863 356
I was trying to save some $$$
2.) This part of NCAT's writeup in regards to MSD80 ---> MSD81
My production year again is 02/06/2008 so my car came with MSD80, 1 month short of MSD 81 03/2008 unfortunately
--MSD81 ECU (12 14 7 616 431 ) - if you have 2008/03 just skip this part
Ncat's wording is a bit off
Part4 ( Replacing MSD80 on MSD 81 ) ( if you have 2008/03 > just program it )
Replace you MSD80 on 81.
Very important! you can't use used MSD81 unit. you should buy it new
Program it on Zub 7628542
Do not forget to transfer values about injectors in the new MSD81.
so I have a MSD 81 that I bought "Used" and had Programmed / Transferred / Cloned from my original MSD 80
"Very important! you can't use used MSD81 unit. you should buy it new"
from this part of NCats writeup:
My Question is : I can absolutely NOT USE my "Used" MSD81 that was programmed from my original MSD80 ?
Thanks in advance and Sorry if these question have been posed before or help it helps someone else
armenh7
20
13
@doublespaces
1. Based on eBay listings of part number 34516789303, it should work. The cross-compatibility model list on realoem ranges from 328i all the way to 335is.
2. You can use the current MSD81 just fine. You'll just need to flash it with the ZUSB with winkfp.
DSteele41
Thank You
DSteele41
Hey guys,
last weekend I did the wiring for my dct swap. Iam a little bit confused because my old X6021, X6031, X6041 female connectors that came from the transmission has 2 rows with 4 big Pins. So my original male connector has it, too. The new connectors of the dct wire have 1 row 4 big Pins and one row with 8 small Pins like the wiring diagram.
Can anybody tell me if that is normal?View attachment 22829
I was wondering the exact same , I'm in the middle of my DCT swap now, and I think I finally made sense of it, You re-pin the connectors on the Male ends of X6031 and X6021 and not the female ends; just swap the DCT Transmission harness in and take out old 6AT harness
can anyone confirm ?
DSteele41
I used the same harness, This is the schematic I used and it worked for me
I'm starting my wiring for DCT swap to 2008 E93 N54 production Date 02/2008
Does the below sound accurate ?
I believe I've got this figured out now with some more exploring of the Transmission Harness for DCT
a Question
--- When the Diagram Attached referrs to Re-pinning X6031 and X6021; 10--->7 on X6031 and 7/8------>11/2 on X6021
1.) it's referring to re-pinning the pins on the Male Connectors that of both X6031 and X6021 and not the re-pinning the female connectors that comes with the DCT Kit: p/n 12517581112
Thanks,
Amirhrgarage
CF26:
Anyone fix this issue ?
Justfloatn
I'm helping my son perform the DCT swap on a 2011 N55 and I have a question about the rear diff and axles that came with the kit. What is the difference with the rear axles? They look the same as the axles we have now. Are the axles supplied as an upgrade on the N54?
