6AT to DCT Converstion
E60535i
xHP once mentioned the possibility of licensing his product out to 'pro tuners'. Understandably, over the past several quarters, his focus has been on casting a wide net — covering as many chassis and 6/8HP variants as possible, while adding a degree of customization — which makes business sense. He's better off making 97% of his target audience happy than spending his time on individual tunes and not meeting the needs of those who want anything from a basic update to different variations/personalizations of each of the tune stages. Perhaps, once the dust settles a bit, we'll have either pro tuners or even further command of the tune, with an additional module and corresponding license/fee. Either way, I've been in touch with him enough for him to know (and I'm sure others have also chimed in) that there are specific scenarios that cannot be accounted for with the customization module. However, these particulars make up a small percentage of all use cases — thus, understandably, pertinent solutions are currently on the back burner.
With regard to your torque reduction, although it seems counterintuitive, increased torque reduction can yield a faster shift time, in many cases. This, as it allows the clutch release of the off-going gear and clutch engagement of the on-coming gear to be less counteracted by input torque, facilitating shift completion within a tighter window and with less heat/wear. My sub-200 ms shift times have been the result of incrementally adjusting each shift to have a greater torque reduction. This, of course, can be overdone — thus, it's important to adjust and test (and allow full adaptation), incrementally. However, when dialed in (at least to the degree of precision that the customization module will furnish), you will likley not want for another transmission.
In terms of a weak point, I don't know that I have been exposed to a big enough sample size to be able to tell you with any authority. Some people have one thing fail, while many others have never experienced the same kind of failure and vice versa. My recommendation is to manage both overall torque levels, shock loads, and clutch slip at high torque loads (the last 2 the product of a combination of shift speed and shift torque reduction). For example, I don't doubt that a healthy and otherwise stock transmission can handle 700 WHP (even without PD clutches) — IF one manages the above areas. In terms of torque levels, rather than generating maximum torque as early as possible and then having to taper it off sharply with increased RPM and increasingly toward redline, I prefer to still reach peak torque early, but limiting it down low, to hold a flat torque level to redline. Generally speaking (with supporting hardware), this allows for a 'cooler' run to redline and allows for repeated runs with very consistent output (and encourages one to manage the ratios more appropriately). This, as you can imagine, is far easier on the power/drive train, without sacrificing peak power output (oftentimes making it more accessible more consistently).
Lastly, on the torque converter, with the Gen-2 6HP, aside from launching, the torque converter is essentially out of the picture. When driving off at a moderate pace in D, for example, the lock--up sometimes occurs at or below 1,000 RPM and remains locked until back at a near stop. When moderately driving off from a stop in 2nd gear, it allows a bit of RPM flair for additional torque, but transitions to a lock, once the target lock-up RPM begins to align with the TC RPM; and, thus is only open for a very short duration (and locks well before it shifts into 3rd). Otherwise, under hard launch in any mode (D/S/M), yes, the TCU will allow an initial torque-tapping flair until the TC and target TC-lock RPMs become more plausible — not too dissimilar from when one pre-loads the TC while staging a launch. Otherwise, there's virtually no scenario in which the TC handles the full engine load (and thus all of the torque). The TC is generally locked long before reaching peak torque, for example, and remains locked throughout the power band and even between shifts. I don't see a scenario in which a TC swap should be the focus of one's upgrades, between stock and ~750+ WTQ levels. And, even if one plans on reaching higher WHP levels (than the aforementioned torque levels), one can simply limit the torque output in either the TCU (with caps specific to gear) or DME (for overall caps or caps by gear and/or RPM) calibrations. Unless I was targeting 850+ WHP and wanted to make just as much torque as HP (with PD clutches and TCU calibration, of course), I wouldn't make the TC a concern. And, even then, it would only be a matter of tuning or tapering the launch appropriately.
4,345
I have a 'custom' xHP tune from @RayBan but this was before you could customize the shift points. In M mode, it is setup to autoshift but only at redline and it will hold the gear if the kick down is pressed, in addition to some shift point changes. I'm not sure if he does custom tunes anymore.
AJL
43
27
2011 335i M Sport
Alright, so I'm in the middle of this swap and the shifter wiring is killing me. To get a clearer understanding of what needs to be for this, I made a diagram showing where to re-pin all the AT gear shift connectors to. Does anything stand out as being blatantly wrong here?
I used what info is out there already and newtis wiring diagrams to create it. Lines with arrow ends represent moving a pinned wire, circle ends are taps/splices.
EDIT: This is on an N55
4,345
Unless I missed it, I recommend providing the build date of your vehicle as well as chassis code. The swap details are different within models not to mention across years and chassis.
AJL
43
27
2011 335i M Sport
Ohh look at that, my signature isn't setup on this site :p Anyway, it's a 2011 e90 n55.
At this pointI'm honestly most concerned about where/how exactly to tap into the PT-CAN bus.
From my understanding, there shouldn't be any pinout differences between the e8x/9x chassis with the same engine/transmission/dme combos. At least so far as the shifter wiring is concerned. If so, that's news to me and a little concerning that I haven't realized that by this point in the project lol.
4,345
If you just look at the 135i transmission harness and compare it to the 335i harness you'll see there is a pretty large difference. Also some wiring is different if you are pre or post 09. I've seen two post 09 DCT transmission harnesses and the pins are different inside the pig tail. I would need to sit down and study my own notes and compare them to what you've posted, to be sure we are talking about the same things, but to some degree, there are wiring differences for sure.
As for PT-CAN, I don't think it matters. I was simply going to tap the wires from the FRM I think that way I can avoid going through the firewall for anything.
Reactions: AJL
AJL
43
27
2011 335i M Sport
Wait I just realized - are you talking about the harness in the engine bay? If so, yes that's clearly different. I bought one from a 135i N55 to replace my current AT one. Comparing that to the equivalent harness for a 335i w/ DCT it's the same (according to newtis). It's fits exactly the same too!
Anyway, I just ended up using posi-taps for the PT-CAN and 15WUP (Green/red) signals at X14271. Connections seem strong, so it should be fine. Now just to find that engine harness ground bolt I dropped. :coldsweat: It just vanished, you know how dropped bolts do. Once I take care of that, it's time to either flash all the modules or find out where I screwed up lol.
NoQuarter
1,662
1,066
Indiana, USA
Z4 35is, 535xi, X5 35i
Be sure to use twisted pair cable for the PT-can connection and keep the twists all the way up to the connection.
AJL
43
27
2011 335i M Sport
Just an update on the swap - I've got everything wired up and confirmed with ISTA that both the DKG and GWS are communicating correctly with the vehicle. Was able to update the VO and read/write to the GWS without issue using NCSExpert.
Unfortunately, the auto driveshaft (p/n 26107614396) does not seem to fit due to moving from a small diff housing to the large one. The center support bolt holes don't line up, because the back half of the driveshaft is too long. Didn't get an exact measurement yet, but it looks to be about 20mm. According to a thread posted earlier (post #11), I thought this would work. Unless that was only referring to pre-2007 models that used p/n 26107614433.
Either way, it's not a huge deal. A used driveshaft can be had for like $100, or I can have my current one shortened a bit if need be. I'm more concerned about just getting the transmission filled and making sure it goes into gear at this point lol.
27246
AJL
43
27
2011 335i M Sport
New (to me) driveshaft 26107614433 is here and fits like a glove. Already got the tranny filled and confirmed it goes into gear. I think there may be a problem with the sport button, but haven't really gotten to test it. Should have everything buttoned up and at least drive-able tonight.
Can't wait to take it out for a drive :eek:
4,345
Are you referring to this thread?
https://bmw.spoolstreet.com/threads/swap-188mm-auto-pumpkin-for-215mm-diff-cover-options.1561/
The back half of the driveshaft is telescopic, so it should slide inward, no?
AJL
43
27
2011 335i M Sport
Yes, that one
The slip joint is on transmission side of the center bearing, so the back shaft being too long can't be compensated for.
27371
Also, do you happen to know anyone who has done the programming for this swap before? I thought I had it correct, but I'm getting this weird code on the DME:
3BDD - No Message (request torque electronic transmission control, 0xB5), receiver DME, transmitter TCU/HIM.
And the transmission won't shift past second since that throws it into a failsafe mode :(
I can communicate with both the DKG and GWS, so I *assume* the wiring isn't the problem and that its some kind of programming issue. Just don't know where to start. I suspect the transmission is the issue and not the DME though.
AJL
43
27
2011 335i M Sport
Well I was able to resolve the 3BDD error message quite easily actually, thanks to some advise from BimmerGeeks. I just needed to reset all engine adaptations using INPA.
So the car is now running and driving error free!
I still need to put my interior together, figure out what rattles are due to my hasty re-assembly, and fix what sounds to be a massive exhaust leak, but I'd say the swap itself is complete.
m_a_itani
23
BMW 335i M3 converted
Hey guys,
last weekend I did the wiring for my dct swap. Iam a little bit confused because my old X6021, X6031, X6041 female connectors that came from the transmission has 2 rows with 4 big Pins. So my original male connector has it, too. The new connectors of the dct wire have 1 row 4 big Pins and one row with 8 small Pins like the wiring diagram.
Can anybody tell me if that is normal?View attachment 22829
Hello did you make the swap? And what automatic transmission fitted to the car 6hp19 or 6hp21?
houtan
653
331
135i N55 DCT; PS2
Finally got my M2/3/4 flywheel for my DCT 135i. I have a few questions, not 100% related to swapping a DCT, but it is DCT related so i thought i would ask here.
The BMW instructions say to use a special tool to hold the flywheel in place when removing/reinstalling. Do i need that or are there other work arounds to hold the flywheel?
Do you need a special tool to go in the center of the flywheel to make sure it's aligned and centered?
Any other special tools that would help get the job done? For example, i am thinking there may be a trick or uncommon tool to get to the bolts on the top side of the transmission.
Anything else you think may help someone doing this at home?
Thanks,
houtan
AJL
43
27
2011 335i M Sport
Thanks,
houtan
Well, the tool just holds the starter teeth to keep it from spinning. So long as you can accomplish the same thing you should be fine. I literally used a tube wedged between the ground and flywheel teeth to stop it from spinning while torquing down the bolts. :joycat: Honestly though, it would've been nice to have.
I didn't need any special tool to make sure it was aligned. Flywheel is keyed, and I just followed the auto instructions.
As for the top side tranny bolts - I used a metric ass load of extensions coming in directly from the back. It was actually pretty easy that way.
The only other "trick" I may suggest is to do the small starter bolt first from the top by using a jack to lean the whole engine/tranny assembly forward for more room. I think it's #6 on the bolt diagram.
Reactions: houtan
houtan
653
331
135i N55 DCT; PS2
Thank you!
So when you tilt everything to gain access to the upper bolts do you remember where you put the jack? I am guessing just use a block of wood between the jack and somewhere on the oil pan? Did you loosen the two motor mount nuts when you tilt everything?
So I’m thinking I need more extensions lol. I have probably enough for two feet but it sounds like I need six feet.
I’ll have to look at the flywheel when it gets here and see if I can come up with something. I was thinking I could use an impact wrench to remove the old flywheel but like you already indicated, something needs to hold the flywheel when torquing the new bolts.
AJL
43
27
2011 335i M Sport
Thank you!
Pretty sure I just jacked it up on the rear support area of the transmission. It doesn't need to go very far at all, like maybe an inch or so? I didn't bother loosening the engine mounts since mine definitely had enough play. But , you know your car and will have to make that call for yourself :) And again that was only for the single starter bolt because I couldn't seem to get it from the back.
Reactions: houtan
houtan
653
331
135i N55 DCT; PS2
So i have a few more questions haha. @doublespaces, let me know if this is too far off topic and i will start a new thread. these are still DCT flywheel install related.
I am in the process of ordering all of the required parts to do the removal and install. I am also reviewing all of the available documentation in ISTA+ and ended up with more questions than answers. If someone could help answer the questions below i would appreciate it.
Flywheel instruction questions:
  1. Joining torque and angle of rotation must be observed without fail (risk of damage). This is in the DCT install instructions as well. They have a picture of this weird ratchet. Is this really required? I was planning just using my torque wrench.
DCT Removal instruction questions:
  1. Before gearbox is removed, it is imperative that a readout is taken of the specific gearbox data status using ISTA/P. Is this important?
  2. Twin-clutch gearbox must be shifted to position “N” before removal. Is this required? How do I make the transmission stay in neutral after turning off the car?
  3. Apply a think coating of MI-Setral-43N grease to transmission input shaft. Is this just anti-seize or some sort of high temp grease?
  4. Seal off oil cooler line and connection holes on transmission with plugs. What are the part numbers for the plugs?
  5. Does this mean you do not drain the transmission oil before removal? I do not see that as one of the steps.
General questions:
  1. Do I need to run any transmission adaptation resets via ISTA? Here is a screenshot of the options I have.
  2. Do I need to order an new Cylindrical roller bearing (Part 5 in the real oem screenshot). How about the Dowel (Part 3 in the real oem screenshot)
That's all i can think of for now.
  • Remove Flywheel.pdf
  • Remove DCt.pdf
