535i Aluminum Outlets?
Aaron
544
201
Colorado
Silver 2013 335is 6MT
Weird. I was significantly under 525whp and still gained 12 whp and 52 wtq.
Aaron
544
201
Colorado
The same dyno, the same dyno operator, the same atmospheric conditions, the very next day. The only difference was the outlets and a single tune revision to account for the outlets.
Kaane
31
15
2008 535i
Since my car looks like this right now, it seemed a good time to install them. I am sure they don't make a ton of power, but I do like any extra efficiency. They are pretty cheap as well.
My goal is 500whp.
xMZWW3a4_v1-jq3G3aMHW9hsW-vrnJPwACVmGxQkizhRt3c0m0nn_1MpBbINgJDjOqLO1Z0qP1wb5X6J5cOLL-CMnQ=w2400.jpg
Aaron
544
201
Colorado
Did the temperature probe on the dyno also reduce my WGDC by 10% across the board?
I've got the logs, but let me guess, we fabricated those too?
Rcboosted2007
902
90
Parts unknown
07 335i
[ATTACH=full]24213[/ATTACH]
V8bait
#5
WGDC base % logs wgdc base table in logs mostly. There's a few other tables that obv adjust this and move it like the coolant temp compensation and other temp tables I think. Not overly important to mess with those.
WGDC after PID logging, when compared to base, is how much PID is doing. Boost error, p factor, d factor all determine this as well as time and whatever else. Don't get caught up on specifics if you're over it'll eventually remove, but not immediately if it was just adding a lot of positive duty cycle.
WGDC bank X % logging = WGDC base + PID + all airflow adder tables.
Rcboosted2007
902
90
Parts unknown
07 335i
I wasnt thrilled with mmp 1st batch of aluminum outlets, mmp silicone outlets or now the psp. 4rth gear pull mmp s3 turbos
JuniorB
343
112
Rhode Island
07 e60
Bumping this thread as a FYI. I purchased the VTT aluminum outlet for the e60 n54, i wasn’t thrilled with the tight sweep on the front turbo, so I was looking for an improvement. Since purchase, I can say the front sweep is a huge improvement, as for the rear, it’s the same diameter. The pics make them look larger that life, they just don’t have the step that seats into the comp housing. I have to say, it’s a nice piece, came well packaged, with a few goodies, now here’s were it gets disappointing, the rear pipe comes extremely close to the manifold, it’s were the silicone coupler sits, no matter which way I turned it, I couldn’t get it straight with out almost touching. The good thing, is I just hybrid it, I kept the rear pipe, and used the front one, with the nice sweep. Some are going to argue if it’s worth it, I found these compressors are small, and need all the flow possible. This is on a stage 1, with nitrous.
JuniorB
343
112
Rhode Island
07 e60
Here’s my hybrid outlet, stock ported rear pipe, front VTT pipe..
