135i Single Turbo with Samsonas Sequential 6 speed
I will post the result soon☺️
Have new Dyno date tomorrow
I hope everything is going well this time.. had a small problem with the clutch last time I was in the dyno!
Now all issues are fixed..
I be back!!
Fantastic! We await your results.
Dyno date update!!
Result 651whp 833nm
Had some small issues but we had it fixed.
I'm Happy
Nice! Your engine should last if you hang out in that area. Will you take this to the strip or track or both?
328iwagon
12
Coral Springs
Hello, I love this build and I would like to ask you where did you purschase the sequential gear box, I am building mine e91 with the n54 engine for track and 1/4 mile by I can’t see here to buy it from.
I know is expensive but i want it for my build.
Thank you in advanced for you help,
Excellent job on that Bmw !!!!!!!!!!!!
Dreyo27
153
37
Sacramento
2007 335i 2008 535i
I talked to the ECUMaster guys a while back. They do a lot of 2jz into E46. SO they said they have the BMW CAN Bus figured out pretty well. They just can't support the DI on an N54.
Are you can bus integrated?
Is the OEM DME still in the car?
How did you plug the head ports?
328iwagon
12
Coral Springs
I have all original from the 335i, I swapped everything from the 335i to the 328i wagon.
Acu is from the 335i as well.
al original
