I will post the result soon
Have new Dyno date tomorrow
I hope everything is going well this time.. had a small problem with the clutch last time I was in the dyno!
Now all issues are fixed..
I be back!!
Fantastic! We await your results.
I be back!!
Dyno date update!!
Result 651whp 833nm
Had some small issues but we had it fixed.
I'm Happy
Nice! Your engine should last if you hang out in that area. Will you take this to the strip or track or both?
Was this done with PI only?Don't think I will use it on the strip more likely on track.. will try to use it for drifting also![]()
If you've got 12,000 euros laying around, a sequential gearbox might be in your future. If not, then I guess you'll have to just watch from behind the internet. Apparently it comes with the correct bellhousing for the N54. It has a custom made intake manifold, stock motor and what appears to be a jp top mount manifold with individual egt probes which they intend to use as a port injection safety.
View attachment 1908 View attachment 1909 View attachment 1910 View attachment 1911 View attachment 1912 View attachment 1913 View attachment 1914 View attachment 1915 View attachment 1916 View attachment 1917 View attachment 1918 View attachment 1919 View attachment 1920 View attachment 1921 View attachment 1922 View attachment 1923 View attachment 1924 View attachment 1925 View attachment 1926 View attachment 1927 View attachment 1928 View attachment 1929 View attachment 1930 View attachment 1931 View attachment 1932 View attachment 1933 View attachment 1934 View attachment 1935 View attachment 1936 View attachment 1937 View attachment 1938 View attachment 1939 View attachment 1940 View attachment 1941View attachment 1942 View attachment 1943 View attachment 1944 View attachment 1945
al originalI talked to the ECUMaster guys a while back. They do a lot of 2jz into E46. SO they said they have the BMW CAN Bus figured out pretty well. They just can't support the DI on an N54.
Are you can bus integrated?
Is the OEM DME still in the car?
How did you plug the head ports?
