What happens when you completely bulletproof your drivetrain? (Solution found)
MoreBoost
361
143
So if I get an mfactory lsd and axles, will I just snap my driveshaft?
As I'm dct(2.56 final drive) getting an m3 setup is a real PITA.
LMB335is
301
189
FOB FL
13 335is
This makes me that much more happy about my decision to go all in with the M3 drivetrain swap with the custom FD to work with the M3 GTS software. With adjustable LC and moderate power levels (500-600 whp) it should be damn near bullet proof.
MoreBoost
361
143
Just go with the DCt M3 diff. It's 3.15FD. You will love the added acceleration from the lower gears. And with the DCT overdrive 7th, you should not lose much on cruising. It will bolt up, just need a driveshaft.
Apparently 2.81 is as high as you can go before the TCU perceives that the difference from estimated wheel speed is due to clutch slip and goes into limp mode or throws some other hissy fit.
LMB335is
301
189
FOB FL
13 335is
This. If you're going to go through the trouble of the M3 drivetrain install, which is actually pretty simple, even with getting the driveshaft shortened, you can stay with the 3.15. Sure you'll sacrifice a little on the top, but spend another $500-700 and upgrade to the M3 GWS and supporting parts, use the M3 GTS flash and pick up adjustable launch control, drivelogic, and all the other little things that makes the M3 version of the DCT so much nicer. I do a few 1/2 miles events a yr so I opted to spend the extra $ for the 2.81 but it's not necessary.
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
Should be as simple as going in, and changing a few tables to keep the DME happy, but don't quote me on that.
1,152
1,202
Scottsdale, AZ
No more broken Diff Covers...
We also made an aluminum Guibo to adapt the Samsonas to the M-Factory Carbon Driveshaft we are running now.
We are considering making these diff lockdown kits for the 335 rear ends, and also aluminum guibo for race use only depending on demand. Most likely not right away, but we have all the drawings now for later use if needed.
houtan
650
331
135i N55 DCT; PS2
Does the 2.81 diff have or work within the stronger yolk like the m3 diff?
