Specifically the part where he says he went through 2 HPFPs. @Chris@VargasTurboTech I saw your post asking the customer to contact you. What was the outcome, was the situation resolved?
The situation was resolved prior to me getting involved -I just wanted more info from a test perspective. The actual pump mechanisms were undamaged, it had to do with the pump mounting method and alignment of the drive spline. Unfortunately since I didn't see the parts first hand I don't know if it was installation (most likely) or one slipped through out of spec (not likely but technically possible). Regardless, moving forward we saw some room for a little refinement; nothing worth calling it revision 2 or anything, more of a marginally better construction method process on our end that makes the final product even stronger.
Chris
