Yes, its more important. If you have a injector that is even slightly questionable. On PI you can get away with it as you are not asking them to do so much, this system will find any weaknesses in your fuel system, but I did find under 30 psi, its not nearly as sensitive, I was making in the 740-750 range over, and over, and over on about 27-28 psi, when I turned it up a little bit, I had to swap two injectors to keep it out of fuel induced misfires. The more boost you run, the more sensitive it becomes.
