Vargas crank hub bolt capture question
MoreBoost
361
143
Is it possible to fit the crank bolt capture to the car without removing inlets, fan etc?
I've not had a look yet. I don't have a lift but is it maybe possible to fit from under the car once the tray is removed? Anyone fitted one?
Thanks
Reactions: Twinz
Twinz
23
Cape Town, South Africa
335i RWD
I did mine in 2017 and had to remove radiator fan and inlet for clearance. Working from the top was easier. Access from the bottom is hindered by the transmission oil cooler lines.
After removing the radiator fan and inlet check if the capture plate holes aligns up to the crank bolts. My Vargas capture plate did not fit at all...could have been a RHD issue...dont know.
I had to have the holes on the capure plate redrilled to match the crank bolts location. But other than that it was a straight forward install and glad i did it for peace of mind. And remember to TQ the new bolts to spec.
MoreBoost
361
143
Thanks for sharing your experience.
The fan sounds easy enough to remove. Not sure I can take off my inlet though.
I'm wondering are those lines to the transmission cooler actually coolant lines that can just be disconnected and then put back?
I don't really want to do this from under the car though to be honest. I worry about it falling off jack stands and crushing me.
I'm also right hand drive (UK) so hopefully my bolts will line up. Seems a bit of a lottery.
Reactions: Twinz
KevinC39
234
118
Yeah if you're not sure about how to use jack stands then I certainly wouldn't be crawling under the car unless I'm misunderstanding your concerns. However, I've done a diff swap, down pipe, cat back, and a clutch all on jack stands with no problems at all.
MoreBoost
361
143
I've used Jack stands plenty. I just always worry about physical failure like a weld letting go. Wouldn't take much to kill you. What a way to go.
It was more a concern when I did my transmission. I had a hot running exhaust inches from my face. Having that pin you down would be a horrific way to go.
3,618
There are a few things that can be done to increase safety on the ground.Certainly a decent set of jack stands that are beyond the weight limit with good welds, for starters. I like to keep a hydraulic jack under the car at a central point at one end for insurance.
I think a far more prevalent concern is that the car has been properly set on jack stands. Both placement of the weight distribution so that it won't teeter, that the jack stand lifts are securely positioned on the car, and that the jack is loaded vertically.
mt_n54
23
Off topic, but has anyone else experienced rusted crank capture bolts? I’ve only had mine on for 3 months and the bolts are already starting to rust.
Should I be worried?
3,618
Where are you located? Salt on the roads? Light coat of oil won't hurt the black oxide finish, I imagine.
2,197
replace them with bolts that will not rust?
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
They're steel. Some surface oxidation is both harmless and completely normal. If it bugs you, wipe them down with a rag that has oil on it, or as Torgus suggested, you could replace them with a material that you prefer that does not oxidize.
mt_n54
23
Ok.. Thanks for the reply.. I’ll clean them and lightly oil them..
Ywph
F80 M3
Hi guys bump but can anyone tell me the size full specs and or part number for the hub capture bolts. Please
Ywph
F80 M3
A customer ordered at a shop by me in Germany he doesn’t want it now but the bolts have gone walkies . I’m fittion on mine but no screws.
2,197
Call VTT directly vs. waiting for a reply on the forums I would imagine would be the fastest solution.
MoistNapkin
104
89
08 135i
My question is why does it fully encapsulate the bolt when it doesn't go under any kinda of stress aside harsh vibration? Wouldn't a metal disc work just as well, and also give you access to the bolt for use while walnut blasting?
