Are you out in Suffolk I am looking for a tuner and also was interested in your car club
I'm mainly in the Dutchess/Orange County area. I try to keep the branches comms channels separated so......
For tuning inquires shoot me an email to:
[email protected]
For inquiries about the Car Club, send email to:
[email protected]
@Twisted Tuning how old was that HPFP and did the pins seem tight in the cylinders? Was the oil clean or did it look like old gear/diff oil? I'm trying to work out if they simply wear out over time due to the oil not being serviceable.
I've taken a few apart and the oil always looks the same. BAD. I wouldn't say super dirty persay. But I will say that no oil should be left unchanged. of the HPFP's I've opened up there were a few different failure points.
-fuel chamber hairline fractures
-piston damage (cracking or somehow burred)
-solenoid wornout
-internal HPFP valve gets stuck open or closed
-HPFP filter clogged like hell
Being that virtually each one had a different failure, it was tough to decide what the cause was. but couple conclusions.....
-internal failure due to high ethanol content which in turn drastically lowers fuel lubricity (I usually tell all my clients on E85 to run a couple tanks of regular 93oct through the car every 5 or so tanks of e85 if they are running E50 or more). Being that lubricity it can increase heat build-up.
-oil needs to be changed/serviced periodically just like everything else on the car. old fuel diluted oil in there if a seal goes bad will cause failure
these are just my findings on like five pumps i've completely torn down. I'm honestly not sure what type of oil they used in them. I couldn't get a distinct scent off of them since they were all pretty much past the point of breakdown.
Off topic: anyone here willing to donate or have a spare I can purchase of an N54, N55, and Late E or F series N55 vacuum pump assembly? I need all 3, so if anyone has some laying around they are willing to donate or allow me to purchase, it would be much appreciated. Let me know.
