Surge killing turbos
1,929
664
I think you’re right. I’ll play with the tune.
Check the throttle sensitivity . With high torque low rpm you can actually feel the flywheel and it can cause car to move and your foot to move very small amounts and with no filtering ,well you get the idea .
1,929
664
So if not a hardware issue, what is happening when someone reports the "chugging"? I'm trying to wrap my head around what this even means, until then I can't identify a solution.
Is this open throttle surging? Or perhaps the BOV literally being pushed open due to throttle closures and pressure differential?
You got it . When you are at boost threshold and the tune base wgdc isn't dead on the pid algorithm goes wonky cause you have a bov throwing a variable into the mix.
1,929
664
Also @Hoffman if you dont have stock mounts you really just may be lugging the motor and feeling it . I would flash to stock and see if does it If yes then you got prob if no its prob just pushing motor way past its comfort level
Hey, I didn’t know this. News to me. Something to keep in mind. EDIT: (This is a great thread.)
This is my experience too. 10psi spring seems to snap shut faster and I get better response when driving sportily.
This was also my experience. The 10psi “plain” spring seems more responsive than the 8psi “white” spring.
But now I’m noticing for the first time “chugging” or “lugging” at low rpm (below 1500 rpm) in 3, 4, or 5th gear going uphill. I’m not sure if this is due to BOV / spring or something else. Thoughts?
(One other thing to consider is whether the low rpm lugging up hill is a result of the transmission tune. I had recently flashed xHP Stage 3 V2.1, upgrading from Stage 3 V2.0. It kind of surprised me that the tranny was shifting up under low torque request below 1500 rpm...:headscratcher:)
The chugging you experience is tune related. I don't think it is xhp or BOV. BOV works correctly with whatever your engine is doing or not. I don't think it is the cause of the chugging sensation.
My car does the same regardless of the spring rates. Low rpm midpower acceleration to sudden high power acceleration results in lugging the engine and slow response. You have to be mondful when you want to accelerate quickly. Make sure you are not in the lugging range.
1,630
This is also possibly on the mark as I had updated the throttle tables (zeroed out) to make the engine more responsive. So I’m lugging it most likely. The simplest thing to do will be to flash my previous tune that had the stock throttle tables and see if I still get that low rpm lugging. Stay tuned!
2,198
This is in D mode? I don't have any hills where I live so I can't really test this out. I can only speak from my experience with a single turbo, there is no way I'd want to be at 1500 RPM going up a hill. If I'm cruising on a flat road perhaps but honestly I like to shift when I dip below 2k.
Yeah with a light weight flywheel and single turbo I shift at 2k as well I always keep it above 2k regardless of grade. No reason to lug it at 1k rpms which is my idle rpms.
1,929
664
Not to mention 300 hp at 1500 Is like 600 at 3000 on rods so if you manage to hit 400 that's like 800 . I would think that's why 700 to 800 at 3500 rpm Is the magical bend a rod number, bmw built in margin and since it's a midrange engine stock it can handle tons of power up top. But that's also why stock turbos can bend rods no prob , obviously I realize it's not as simple as double rpm double the force , in some ways it's worse cause usually increases at delta but also inertia and momentum play a roll as well .
1,152
1,202
Scottsdale, AZ
It's cylinder pressure that buckles rods. Cylinder pressure at 500 ft lbs and 1500 rpm is very similar to cylinder pressure at 500 ft lbs and 6000 rpm. There is more to it than measured torque though, an engine has many different forces on it as it operates, and one big one that people often forget about is inertial loads. Where we're concerned, inertial loads put rods in tension, offsetting a portion of the gas force. If you revved the engine high enough it would offset all of the force. Torque is torque regardless of RPM, but the higher you rev the engine the more torque (increased cylinder pressure via increased boost, timing, or both) you can add before rod buckling becomes an issue (tuning and flow aside). There are, of course, other issues to deal with when revs are raised, but that's it in a nutshell.
Relatedly, when choosing a platform to take a (stock) NA motor and decide to turbo it... if that NA engine has a very high RPM limit, it'll probably hold up to being boosted well. It was built for those high inertial loads. BMW S65 or Honda S2000 for example.
Chris
1,929
664
Chris
Insert hp where i wrote tq was doing it from work and not paying attention I meant 200 hp at 2g Is like 600 at 6 and so on
iminhell1
419
207
Valves cover was cracked so I replaced it and it defiantly feels better, now I have this strange squiggle and my fuel trims just bombing out. Any ideas ?
Only thing I think I see is the wgdc. Looks like it may have been tuned with that VC leak. Now that it's gone it's hunting. WG needs some help.
I don't see anything else that stands out or looks abnormal enough for concern.
DCT_JAY
66
16
2011 335is DCT
Shot my tuner a E-mail, i will update any changes with the updated tune if he sends me one.
jts1981
46
28
NYC
Z4
Check your tune. Throttle closures in combination of too strong a spring or poorly setup BOV can cause this. N54's need the black spring for proper BOV action on a Tial, orange for Turbosmart. Run a dedicated line to your manifold, no "tees" or branches off. 1/4" line is recommended. If you do that, and still get surge, have a long talk with your tuner.
Does the Vader Solutions adapter fall into the "do not use" group?
I'm running it right with GCLITES, tial bov w/ black spring.
Here is my latest log...boost is very sloppy .
DCT_JAY
66
16
2011 335is DCT
Reactions: jts1981
jts1981
46
28
NYC
Z4
my buddy who runs Rb Twos looked alot like this, told him to check his couplers and sure enough there was one that split on the lower chargepipe coupler.
Thanks I'll make a note of that. To be clear you mean between cp and fmic outlet?
The shop did a smoke test and only found a small leak by the catch can. They tightened it all up and no more smoke leak but the logs haven't improved by much. It's quite the headache. They claim any leaks would have shown up with the smoke test.
I'm dropping the car off next week so they can really take their time for a closer look.
DCT_JAY
66
16
2011 335is DCT
These are some things to have checked that i hunted down forever since i barley have time to work on my own car.
1. Tmap sensor "O" Ring has split on me 3 times ( ended up switching to a tial and had to get new chargepipe and never happened again) and the bolts that secure the Sensor into the chargepipe can leak. ( Just take them out and put loctite )
2. Cracked Valve cover ( this mf was such a pain in my ass for the longest because i overlooked it)
3. Split outlet boot twice ( Made my own heatshield for it now and dont have that issue anymore)
4. Both intercooler couplers had small holes that most likely a animal knawed and blew a hole under boost later
5. Chargepipe coupler slipped off underneath so you couldnt tell ( Rookie mistake, just tighten it better)
6. Boost solenoids x2 ( didnt have a issue with them just did it out of process of elmination)
7. Injectors replaced with Index "13" (technically just the latest and last updated version of the Index 12's)
Note: none of this happened all at once, just a brief summary of what ive fixed when i was having boost\vaccum leaks through out my ownership.
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
