Stett Performance Vacuum Canister Review
ajm8127
69
136
PA - US
2007 E90 335i
Not volume as in flow. More like storage volume.
I think this is correct. They are similar to hydraulic accumulators.
The reservoirs even out the pressure in the system when an event occurs like the solenoids open fully to spool the turbos or when the brake pedal is pressed. Without the reservoirs the vacuum system volume is small so any flow to the waste gates or brake booster would result in a larger pressure change in the system until the vacuum pump can catch up versus a system with reservoirs. I don't think it is a mistake that they are placed close to the solenoids.
They are like capacitors in electronics. Capacitors store electric charge and resist changes in voltage. One way they are used is to keep voltage consistent when changes in current, or flow of electric charge, occur. The vacuum reservoirs keep vacuum system pressure consistent when changes in vacuum flow occur.
I agree that if the reservoirs are replaced, the replacement should have the same volume. I don't think it is important if that volume in made up by one or multiple reservoirs.
Reactions: screaminfast
I use 6an which is plenty and is around the same size as stock.
I custom made my whole line from vac pump to booster
Make sure to use the right hose as most think any hose will do but they collapse under heat.
You want to use a braided hose or similar.
screaminfast
256
135
Rochester NY
mikecentola.com
07 SG/CR 335i / 17 X6 x35i
you can use silicone vac line for the small hoses but for the main booster hose use a braided reinforced line.
if your anal for detail you can use a one way valve on the vacuum pump to canister so the vacuum does not drop when applying the brakes repeatedly or you have a vacuum operated flapper on the exhaust.
It does help with wgc.
screaminfast
256
135
Rochester NY
mikecentola.com
Latest revision:
2 x 5" 6063 extrusion, -6AN welded bung input, 2 x 1/4 NPT weld bungs on output. 1/4 NPT to .170" hose barb. Will use a vibrant -6AN Male to Female check valve on the input side.
ajm8127
69
136
PA - US
2007 E90 335i
6AN from the pump to the reservoir seem enormous. Lets say the ID is 0.34", which seems to be pretty close to a few hose vendors 6AN. This is a cross sectional area of 0.091 in sq. Two 0.125" lines have a combined cross sectional area of 0.025 in sq. More than three time more cross section with the 6AN hose than with the stock hoses.
I suspect the lines from the reservoir to the vacuum pump can remain 1/8 inch. These do not need to be high flow because that is the point of the reservoir - the reservoirs store vacuum to minimize the changes in vacuum pressure. In fact it might be advantageous to have a smaller line between the reservoir and the pump to limit the flow that can revert back from the reservoirs to the brake booster. This is why you would put a check valve in a 6AN line.
6AN and a check valve won't hurt, but it seems way over engineered when the stock lines are 1/8". I don't really think there would be a benefit to a change like this especially when the lines that matter (reservoir to solenoids to waste gates) are still 1/8", but it is your money.
screaminfast
256
135
Rochester NY
mikecentola.com
You're absolutely right. When costs of say -4 or the .170" fittings are the same as 6AN, it seemed to make sense. Since I'll be running 6AN for the brake booster line and re-routing it more cleanly, it made more sense to use a 6AN tee and an extra 6AN line vs a 6AN tee with an 1/8" NPT port and another nipple. If I could run -4AN or -3AN all the way to the solenoids I would, but I'm still twins and factory solenoids.
Reactions: ajm8127
No such thing as over engineering, you done the canister the way it should have been.
Now go and build it I love to see the finished product.
I'm glad I'm not the only one that loves doing their own stuff instead of just buying what's available off the shelf.
derekgates
740
375
NW FL
derekgates.us
2011 335is
I don't have the skills to make on my own, but would love one of these custom canisters!
My canisters work fine, but they are rather large and ugly... :p
