Speedtech Twin Scroll N54 bottom mount kit Released
Jan 19, 2017
22
40
Good find. Will you be modifying your manifold to fit Gen5 gates? Or just not offer the Gen5 gate?
I don't think many of the current kits with the Gen5 will likely see any issues, as there should be enough clearance to function properly, but there is a tolerance stack to this, so to be sure, I'll give the few guys (most choose the Tial MVR) that have the Turbosmart Gen5 a heads up, and add a machining op to take off just a bit of material to ensure a worst case tol stack will never touch on anything going out (Tial or Turbosmart) from this day forward.
Tomball335is
15
10
2012 e93 335is DCT
I ordered a 38mm WG block of kit from Ebay for $30.
Best Smile/$ mod I've done in a while.
Any issues at all since you’ve disconnected the WG tube and blocked off the port? Nothing melting? I’m considering doing this on my kit.
WOT808
81
56
E90 335i
No issues yet. I want to extend the WG dump to exit near the sub frame to lighten any melting worries and for a cleaner sound. I'm waiting for an external dump option from @Jeff@Speedtech before diving in to something custom.
Bmxr152
Lake tahoe
N54 e90 single turbo
Has anyone had the downpipe or dump tube ceramic coated? I'm would love to wrap it to keep temps down but I'm afraid of the possible stress and corrosion it will cause. I'm ready to install but wondering if I should have my downpipe and dump pipe cerakoted and wait another 2 weeks for the install.
JValenzSD
33
17
San Diego, CA
2010 BMW E90 LCI 335i M-Sport
I had the manifold and downpipe ceramic coated and wrapped. I also run a turbo blanket for the hot side as well. Seems to hold up well.
Daniel.B
16
Hey guys! Having big trouble with my Speedtech kit. Running S362.
Issue is bank1 02 going crazy when getting boost, and misfires on bank1 at 6000 rpm. Coils, plugs and injectors are all taken care of.
Running brand new OEM 02s, front and rear. Anyone with similiar issues and soulutions? Anybody running OEM 02 sensors with clean readings?
N54135iAT
37
18
BMW E82 135i N54
is there already an option for open screamerpipe? Thinking about modifying mine by closing the downpipe and extending the screamerpipe to the floor
N54135iAT
37
18
BMW E82 135i N54
A friend of mine ordered one two weeks ago. Should be here in April.
Grüße aus Bayern ;-)
Julian1992
10
Hi there.
I ordered on January 6th and was shipped last week.
a few weeks later, sold out was on the homepage.
greetings from Austria
berns
175
266
'09 135i
This happened to me with my CES ST and it was the o2's. I now run with the VTT thermo o2 isolating bungs and haven't had an issue after countless dyno pulls and track days. Running OEM o2's. https://vargasturbo.com/product/vtt-thermo-isolating-o2-bungs/
Reactions: JimboFresh206
Jewgo
65
28
1r
I deleted my statement above because I just recently got my car dyno tuned and come to realize I have the same issue with bank one. Only under boost my STFT's are unstable and i am having minor lean spike's in bank one. New NTK o2, new index 12's, new NGK 97506 gapped to .020
this is slowly rolling into the throttle showing how it gets worse under boost.
JimboFresh206
289
152
335/635/535/533/633
They don't fit the speedtech Mani :/
For everyone who asked me about the connectors...
JimboFresh206
289
152
335/635/535/533/633
@pysical yeah vtto just sells a copy of the innovative heat sinks.
there are other ways to make an 02 heat sinks (big piece of copper etc.) I dont know of anything thats shorter/shallower that still has the semi closed tip to help with pressure :/
_Calle_
52
24
Germany
e82 135is
Finally I would also post a few pictures of this nice Kit.
The fitment and the quality is really fantastic, thanks Jeff, also for the fantastic support!
So, pictures say more than words....
69820226-7cf7-4969-b677-502af96f7144.jpg4300e36a-a8f9-46ad-8b9c-6313b17bbac8.jpg6699e2cc-bf9e-44fd-9456-d02657848255.jpg9b110007-2d52-4039-86f4-a1afb91ad4b6.jpg06ea6c7b-8b4b-487b-951c-cc6bc03f346e.jpg9258c0c9-f811-45ba-a0cb-0dc32898d30f.jpgIMG_4785.JPGIMG_5486.JPG
_Calle_
52
24
Germany
e82 135is
I ´m running OEM O2 sensors (more than 25k miles on it) with no issues so far, but still running on spring pressure.
