Single Turbo peeps... what O2 sensors?
rac
341
205
135i ST
Another question is, are the adv sensors, kit dependent? Like wont work with a certain brand due to placement on manifold? I heard that. Would like to know if thats the case with docrace manifolds as well for them. Id look into that also.
I think the the likelihood of success of any pre turbo sensor combined with the stock ecu is going to be somewhat dependent on the manifold and relative sensor positions.
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
It's a sensor... the DME has no idea what the manifold is shaped like nor where the sensor is on there. All it sees is voltage / current which gets translated to AFRs and sensor system checks, etc etc.
Fact is ADVs are expensive for what they are ; they work for some but not all and there is no clear reason why.
1,286
781
They are pre-turbo sensors, so why wouldn't placement have an impact, based on pressure differential? It would be interesting to see if the works/doesn't work is evenly distributed among all single turbo users regardless of manifold, or if a certain manifold design/style is more prevalent to having them not work.
The Convert
1,486
1,040
Only way I could see manifold design making a difference would be in runner diameter for manifold pressure and proximity to head for temperature.
Reactions: veer90
rac
341
205
135i ST
Because I believe it has an expectation on how long a change should take to be read. A change in fuel that is. Similar reason putting both sensors in the down pipe doesn't work, it expects different values when changing bank fueling independently. I suspect it has a check on time to get that information back also and maybe some ecus have are more complex than others and so there is a difference between who has had success there. I.e. the ijeos might be less forgiving.
tsaulsbu
23
Have 4,200 miles on my NTK's with the Innovate heat sinks as described before, no issue. Daily driving, extended idling, 60+ highway pulls, and 30+ dyno pulls
Additionally I figured out my AFR slow response "problem" which was really an install error. When you enable single rear O2, make sure that the bank 1 rear O2 sensor is actually placed first in the downpipe. lmao
@veer90: Did you use copper crush washers to get the heat sinks aligned properly? Or did you just anneal the supplied washer (or just happen to get lucky)? And, did you have to remove the compressor housing in order to make room for the heatsink install, or were you able to get away with removing just the air filter?
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
I used a dremel on the supplied washer. only had to remove filter.
tsaulsbu
23
I spent about 45 minutes grinding down and annealing the supplied washer--got it down to about a 1/8 turn away, but then the washer tore through. Ordered a pack of these, and they worked perfectly w/ no modification on a DOCRace n54 manifold + HBX-1 heat sinks.
gingerbreadman
36
SoCal
I'm IJEOS and running ADVs. I'm getting 29E0 (mix control) accompanied by a CEL. i really hope I don't have to switch to NTKs as these ADVs weren't exactly cheap.
135i2
98
99
135i
Running IJEOS with two new ADVs and they are spot on despite still dialing in the tune on 98 (93 in USA) and different mixes of E85. They log right over the top of each other. Perfect.
V8bait
505
785
Texas
I'm tuning the car myself, does he cater to self tuners or am I forced to buy a tune on top of the sensors?
You can tune them yourself you just need to use the mhd checkbox and modify the two tables for calibration in the .bin, you have to estimate one of the values based on your turbo setup but it's easy. He can provide the tables/calculation for you or just send me a PM and I'll forward them to you.
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
I'm running NTKs / Densos and I'm guessing none of that applies to me. lol
Thanks though :)
AllSchwarz
Destin Florida
2009 e92 335i
Just installed ADV o2s brand new when I installed the single turbo kit. Just over 1000 miles now but 900 of those 1000 I have had trimming control codes (2C31, 2C32) from both banks. I am still on JB4 with a pre loaded BEF. Going with a Twisted Tune once the car is fully set up. Emailed Twisted seeing if these codes are something that can be adjusted and fixed during the tune but haven't heard back. I am about to switch to NTK's because my turbo is out and the o2s can easily be changed out so why not. Maybe some of y'all can give me some input.
