Single Turbo Boostbox Tuning
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Does that thing really not make full boost 'til 5,600?
72mm turbo on 93 so it’s not going to spool as fast as a 6266. For reference on 93 6266 will hit 20 psi around 4100rpms. Now I haven’t tune spool mode or the Vanos tables yet. I can probably get that down to 5k rpms once I get the boost control figured out
iminhell1
419
207
Oh I figured you where on an all out fuel with a tubskie that big.
I'm working on the s366 kit and going to try and put it through full pace.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Nah on none oxygenated gas you can get about 600-650 whp before having turn on the Port Injection. It's just been raining so I haven't been able to get anymore datalogs to fixed the tune yet.
Next update I'll lower the boost target in the lower rpms because I believe that's causing PID to time out. Then worked on fixing the timing correction. I believe my bank 1 oxygen sensor is going bad because it can't keep the 11.5 afr I'm requesting and it bounce between 10.5-13.1 where bank 2 holds it steady. Might have to get my hands on some ADVs
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Update. It’s been raining hard due to the tropical storm. However, I the NTK o2 sensors do not like speed tech manifold. So I’ll have to get my hands on some ADV sensors.
chrisdfv
270
216
E90 335i
My buddy runs ADV sensors on his speedtech kit. @WOT808
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Went ahead and order 2 adv sensors from Jeff. He has them in stock and they shipped within a day.
