But there is no need to pump air back into the motor as this would reduce the effectiveness of the low side system.
Catch can volume only helps scavenge the oil better from the gasses that are getting passed through it, the biggest thing is how quickly they can pass
under extreme conditions and at high volumes.
Vacuum actually helps with piston ring seal so you don't want to introduce and extra gasses into the crankcase.
